SDA-2A, Any experience replacing the puckered membrane on the passive radiators?
I was able to remove the old material, and have fashioned some replacements of automotive upholstery.
The new burgundy inserts weigh a little more than the old membrane.
What will happen to my bass?
I was even thinking... maybe a quarter or a silver dollar in the center, under the upholstery might improve my bass?
I'm not beyond adding real 12" woofers...
Answers
  • invalid
    invalid Posts: 1,455
    Not a good idea, leave them alone or try and find some used ones.
  • Gardenstater
    Gardenstater Posts: 4,779
    You. Removed. It? This is not going to fare well, most likely. The weight and compliance are critical.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • aprazer402
    aprazer402 Posts: 3,384
    Your upholstery idea doesn't look right to me. You're free to do what you want. But the vast majority here will recommend repairing with the original parts. If your design doesn't work out, you should look on auction and sale sites for the exact replacements, which are the "SW-121" passive radiator. Welcome, many very smart people here willing to help. Audio enthusiasts can be persnickety. Use the search function and ask questions.
  • Baker
    Baker Posts: 18
    Looks like I’m going down the wrong path.
    Thanks for that part number. I’ll start looking for some replacements.
    Not out anything, as they were in terrible condition.
  • aprazer402
    The Polk SDA 2A's present an amplifier with a true 4 ohm or even lower load. Which requires an amplifier of sufficient wattage, preferably high current AND can accept 4-ohm speakers. These are not easy speakers to drive. Very few older receivers and most newer ones cannot accomplish this without damage to either the amplifier, the speakers or both if over-driven even modestly. An integrated or separate power and pre-amp would be recommended by most here.
    Toolfan66 Posts: 18,035
    edited April 2022
    I’m going to go against the grain here, only because you have removed the other material, and I am also very anal, so I wouldn’t want the bubbles in them either.
    At this point what do you have to lose? The only thing I would recommend is finding some other material (black as well) that may be a better match, hell maybe an upholstery shop would be willing to do the work? Maybe not cost effective on these.
    Anyway at least if it doesn’t work out you can play with these till you find something else, like you said they were in terrible condition, not like you can call up Polk for replacements..
    My vote is to go for it, but find some better material, maybe Joann’s has something…
    Have fun…
  • Baker
    Baker Posts: 18
    Appreciate the kind comments, thank you.
    As for my amp set-up: Yamaha M-80/C-80
    Have the switch at the rear set to 4 ohms.
    Thanks for helping, to all!
  • Baker
    Baker Posts: 18
    Quick note to Toolfan66:
    I also share your love of tools.
    35 years as Tool Maker
    Every major manufacturing joint in town...
    One must remember that manufacturing is not only quality driven, but so also by economics.
    Bet Polk had less than a nickel in those membranes...
  • Gardenstater
    How did you separate the surround rubber from the membrane and the membrane from whatever is behind it (styrofoam)?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 51,747
    The weight of the membrane, as you called it, is critical as it is used to tune the bass response.
    Never replace the PR's with active drivers, it simply will not work for many reasons.
  • Baker
    Baker Posts: 18
    Little bit of heat, and it peeled off with ease.
    The surface below is very shiny and slick. A plastic material ~.020” thick. A poor surface for adhesion, thus the puckering problem.
    I don’t need to use the word membrane.
    Please share the actual term for this part.
    I would be pleased to know...
  • Baker
    Baker Posts: 18
    Re: Driver in lieu of radiator
    That concept would require sealing off the upper portion of the cabinet. (to maintain the “airtight” condition around the mids and tweeter)
    The lower portion of the cabinet would then require porting.
    Just a theory, and was hoping for some brainstorming to occur here...
    Polk couldn’t get a driver in them, and hold the $599 sale price.
    F1nut Posts: 51,747
    Stop trying to reinvent the wheel of which you don't seem to even begin to understand.
  • Baker
    Baker Posts: 18
    Ok, thanks for the help.
    txcoastal1 Posts: 13,511
    edited April 2022
    A passive radiator is more inline with a port than a driver...installing a driver especially that size will definitely s cr ew up the design and sound from the midwoofers
    You would need to completely redesign the cabinet and the entire crossover system
    Clipdat Posts: 13,094
    Baker wrote: »
    LOL, thanks for the laugh. Exactly what I needed after a long day.
    edited April 2022
    I should note that my comment above was only about trying to repair the passives, ‘NOT’ putting a driver in these speakers, that will not fair well at all. I missed that part of the post.
    I still stand behind there is nothing to lose at this point trying to find some material to repair them, there will be very little cost, and if it fails, they are still garbage, if it works good enough till he finds replacements, no harm no foul IMO..
    We have guys putting armacell inside driver baskets, cutting off dust caps, and apparently with positive results, trying to repair these is child’s play..
    Post edited by Toolfan66 on
    xschop Posts: 5,138
    Can you weigh the old membrane?
    pitdogg2 Posts: 27,033
    Lets stop for a moment and reevaluate. When Polk did away with the foam on front for the weight they added weight in the back in the form of a bolt, possibly a carriage bolt. This bolt was in the middle of the neck of the styrofoam. I've had both SW120 and SW121, IIRC the difference was a foam front and no bolt and a plasticky front and bolt. 12" Polk passive radiators have for the most part been readily available on the auction site.
    Buy some for spares and weigh them for reference to get idea of how much material and glue you'll need to repair the set the foam was removed from.
    I don't believe any foam was removed, only the thin layer of material that was bubbled that was glued to the plastic face you see in the pics above, he is just wanting to glue a replacement piece on these so they are flat not bubbled up as some do. I just think he can find a better piece of replacement material than the pieces he was wanting to use, plus that color would look horrible on them..
  • invalid
    [quote
    Polk couldn’t get a driver in them, and hold the $599 sale price.[/quote]
    I bet it cost Polk considerably more money to properly implement the passive radiators.
    I have two sets of SW150 passives, one set has the extra weight on the back (looks like a carriage bolt) the other one doesn't.
  • Baker
    Baker Posts: 18
    Agreed, I will look for a more “consistent to design” material.
    I do have a scale, and can match weight.
    Color... Yes, I’ll find some black.
    Cabinets are to be wrapped in Hard Maple Formica. Think very blonde...
    Thanks for the real help...
    Toolfan66 Posts: 15,161
    8:30AM
    Yes the soft material that bubbled was the foam I was referring to. Many of that design bubbled, some very badly others just a few spots. IME it never got worse after the bubble, it just looked terrible.
    Interesting @Toolfan66 on the sw150 and the bolt no bolt. I wonder in one of them has lighter Styrofoam substrate verses to other necessitating one needing the bolt to make up the difference.
    I'm aware that the SDA SRS 2 used two different passives. Cabinet was the same only difference was drivers used. I and another member discussed it mave have been one set of drivers that made a bigger difference.
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,766
    @Baker, please don't leave this thread "hanging"; keep posting your progress.
    It is interesting.
    Harry / Marietta GA
  • BlueBirdMusic
    Quote from @Toolfan66:
    ^^^ I like your perspective. I am still laughing from this comparison.
    Harry / Marietta GA
