Jeff Bagby's Helios CM Bookshelf Speaker Kit
stangman67
Fellow polkies,
I am going to use this thread to chronicle my progress and lessons learned on a DIY speaker project I am undertaking.
A few months back, I was looking for a project/challenge to keep myself busy. I have done basic woodworking in the past and I really enjoy it so I decided to mix that with the audiophile bug. Been gathering parts and pieces and tools over the past few weeks and I officially began the project today.
Details on the project, kit and components are from Meniscus audio https://meniscusaudio.com/product/the-helios-cm-loudspeaker-kit/. It is a large "bookshelf" with a 8" SB acoustics woofer, a SB soft dome tweeter with a badass waveguide and a 10" SB acoustics passive radiator.
Here is one of the designers (Javid Shadzi) finish build. His will be way way nicer than mine but gives an idea of the makeup of the speaker
I will be using 3/4 MDF with a 1.5" baffle and internal bracing, and I will be doing an automotive quality paint job on the speakers. I will probably be painting them either British Racing Green or a Cementy Gray. This will be my first attempt at doing a high quality paint job, so plenty of opportunities to screw up and learn!
Anyway, progress pics thus far
Pretty happy with the fit and finish considering I don't have a table or track saw and am making all cuts with a circular saw and guide. These will notionally be going into my garage powered by a NAD C 368, but i MAY try to sneak them into my living room if I can con my wife into allowing it!
FYI this will be a slow build as I am in the Navy and will be underway for the majority of the next few months. I am aiming to get these done by the end of July.
-Zach
-Zach
Also I fully Underestimated the cost of all the little bits and pieces it takes to make a project like this come together. DIY certainly is not cheaper than just purchasing lol, but now I have the stuff to continue to build speakers in the future.2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
Looking good!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I like the 1.5" thick MDF front baffle. What radius roundovers are you planning for the corners? Those must be pretty good drivers. Nice smooth frequency response in that enclosure. Vented pole on the woofer
George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Yea I am very excited to see how these things perform. I am thinking a 1/2” round over, I’ve been toying with doing a 5/8 but might be a bit aggressive2 Channel in my home attic/bar/man cave
stangman67 wrote: »Yea I am very excited to see how these things perform. I am thinking a 1/2” round over, I’ve been toying with doing a 5/8 but might be a bit aggressive
Might be tough. Plans say woofer cutout is 242mm = 9.53". Cabinet width (outer) is 10.5"? If you wanted to get fancy you could make a progressively larger radius as you progress from the woofer to the top. Tweeter could at least have a 1.5" radius at the top perhaps and woofer 0.5".George / NJ
iFi nano iDSD DAC
iPurifier3
I’m not gonna do anything fancy, too much room for error. I’ll probably do a 1/2 on front baffle and the top, will finalize that once the drivers get here and go from there. I’m real afraid of getting this all together and then having a bad tear out, should be able to do the vast majority before assembly on my router table and then just free hand the intersection points after everything is together.2 Channel in my home attic/bar/man cave
That's some really dense looking MDF. Nice choice of DIY. Gotta appreciate the passive radiator on the side too. Should help with room placement options?Don't take experimental gene therapies from known eugenicists.
Got up early and finished the cuts for the other speaker. Made one stupid mistake but had just enough left over wood to create another side piece.
Also for anyone looking for a cheap router setup, this Skil 1322 and its associated router table are a fantastic and very usable combo. 2HP router and table for under 300 bucks is pretty incredible. Has a nice fence, and good attachments to do basically anything you would need to do for light Hobby duty
And because Polk forum, here is the current garage speaker! Monitor 40’s I’ve had for about 15 years. Still kicking
Nice little router table. I've got a homemade one that takes my Elu Plunge Router. Mine is built like a tank but needs to be accesorized more by myself.
What are you doing with the side baffle thickness for the Passive? Are you going with the recommended 1-1/4" there?George / NJ
iFi nano iDSD DAC
iPurifier3
No I am not, staying with 3/4 braced. The plans are wrong, if you look at the minimum internal dimensions and the outer dimensions they do not match up so I had to contact Javid and he told me to just stick with the outer dimensions (and keep the baffle the same exact size while other dimensions could be fudged. Those plans are a mash up between the Helios and Helios CM, the standard Helios uses a BE tweeter and a better SB 9” woofer.
If I had done 1.25 inch side baffle, and kept the baffle dimensions 10.5 wide by 18 tall, the internal width would have shrunk to 8.5 inches and I would have lengthened the cab a bit to get air volume correct (not to mention tightening the woofer cut out).
Decided to just do 3/4 side panel, I’m taking the recommended lumber dimensions with a grain of salt. Hopefully I don’t regret it2 Channel in my home attic/bar/man cave
After doing some maths, 1/2 is the absolute max I can go with a round over and that will only leave a sliver between the driver recess and edge of the round over. I think I’ll be ok but will assess later on. I don’t think 3/8 is enough visually but I may have to go that route for safety, or maybe I can use a thumbnail bit2 Channel in my home attic/bar/man cave
Gardenstater wrote: »Nice little router table. I've got a homemade one that takes my Elu Plunge Router. Mine is built like a tank but needs to be accesorized more by myself.
After doing a bit of research, I may have to do a 1/2” addition to the side panel and deal with the small amount of volume loss. I didn’t realize the thickness of the frame of the passive radiator would be almost a half of an inch!
stangman67 wrote: »Gardenstater wrote: »Nice little router table. I've got a homemade one that takes my Elu Plunge Router. Mine is built like a tank but needs to be accesorized more by myself.
I guess you don't think you could just add some 1/2" MDF on the outside and keep the interior dimensions the same? I'm sure the speaker design is well thought out but he shoulda had someone with some drafting skill draw up those plans
George / NJ
iFi nano iDSD DAC
iPurifier3
I can definitely add a 1/2” panel to the left side but that would end up widening the baffle to 11 inches instead of 10.5. I don’t have the experience to know how much that 1/2 width would affect things but Javid made it very clear that the baffle dimensions were of utmost importance and the other dimensions could be changed a bit to suit my design.
The Helios speaker has very accurate plans, Javid said someone at Meniscus must have drafted up the CM plan and that wasn’t run through him, he said he would try to get them to fix it.
That is such a cool kit. It looks like you are off to a great and have a nice clean workspace.
I'm a fan of SB Acoustics drivers and was actually checking out the Rick Craig Integrity kit (Tribute to Jeff Bagby) at one point. I actually met Rick at the AXPONA shows years ago. He was hanging out in the Van Alstine room if I remember correctly. Sad that both those design gurus are no longer with us.
I've Been wanting to build something for years. Someday....
Hopefully they didn't kit it together like an Ikea furniture piece that is missing fasteners and prone to bad fitment.Don't take experimental gene therapies from known eugenicists.
I’ve always had good luck with ikea!
Nothing too exciting, slowly getting the cabinets built up. I have a limited amount to clamps and doing one panel at a time gives me the ability to bet very precise in fitment, so I don’t have to sand much/use filler or bondo to get all the surfaces in line and level. So far the fitment is close to spot on. My goal is to get the cabinets fully assembled and driver holes cut before I get underway in 12 days. We will see if I can get there
Do you just use regular wood glue? And what about terminal posts/plate options?Don't take experimental gene therapies from known eugenicists.
Using Titebond II, gold standard in wood glue.
I’ll just be using simple binding posts, these in fact
https://meniscusaudio.com/product/big-posts/
Unsure if I’m gonna put them directly through the back of the cab or do some sort of metal trim plate2 Channel in my home attic/bar/man cave
Looking like you're making some nice progress. After taking another look at the plans, besides the errors we have talked about, it looks like the window brace they show would interfere with the passive radiator, which extends almost 3" inward from the outer surface of the cabinet, so about 1-3/4" from the inside.George / NJ
iFi nano iDSD DAC
iPurifier3
Correct. In the cabinet build pdfs, it shows the correct way to do the brace. It will be notched for the passive2 Channel in my home attic/bar/man cave
Wow OK I see.......he cuts a lot of it out to clear that passive:
Very interesting stuff. I feel like Polk could have done more of this in the vintage speakers:
Post edited by Gardenstater onGeorge / NJ
iFi nano iDSD DAC
iPurifier3
Drivers come tomorrow!
I’m as far along on the first speaker as I can be before cutting out the driver holes.
Started gluing the second speaker cabinet today and will be working hard on them this weekend!2 Channel in my home attic/bar/man cave
Do you have some scrap MDF to do the router cutouts in first for a perfect fit where it counts? Measure 17 times cut once
George / NJ
iFi nano iDSD DAC
iPurifier3
I do have plenty of scraps and I will practice for each sized driver for sure!2 Channel in my home attic/bar/man cave
Feels like Christmas in April!
The documentation/packing/materials in this diy kit from Meniscus is first rate!2 Channel in my home attic/bar/man cave
I am a bit ashamed to say I had them assemble the crossovers but I am not quite ready for that, maybe on my next build. I think they did a fantastic job
Both taking good shape!
I also believe I got my foot in the door to place these in the living room! I just can’t paint them British racing green now. Either a deep blue or a cement gray2 Channel in my home attic/bar/man cave
Nice! You have piqued my interest with this build. If you don’t mind, how much did they charge for the crossover assembly? Feel free to pm if you’d like…Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
