Dirac and SDA/L800’s
tjcinnamon
in Speakers
I love my L800’s but I can’t seem to get a good Dirac calibration. I run Dirac with SDA off (unplugged) and can’t seem to get it dialed in.
Anyone have success?
Answers
SDA cable unplugged while taking measurements is good.
I've never used Dirac, however, I have used ARC and it worked OK. In actual use I don't use the AMP that had ARC, I only used it to help me get a picture of the sound and point out any issues. The ARC measurements were taken from 5 positions centered on the MLP.
Are you running the L800 for music or home theater? What issues are you running into running Dirac? Are you trying to solve an issue with Dirac?
I ordered a umik-1 so I can measure with REW without having to change out my amps to something that has room correction like Dirac, audyssey, room perfect, etc.
Here's what my ARC measurement looked like before I moved. I'm in a new house and will need to do new ones. The hump on the right speaker I'm pretty sure was due to room gain because I had a cabinet right next to the speaker, the bass on the left was not as affected by the room because bass would run into an opening to adjacent rooms 20' away to a wall on the left.
- Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
- Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
- Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
- Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
- Office-2.1 B&W Formation Duo and Bass
- Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
- Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
- Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
- Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
- Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
- Maintenance: Pro-Ject VC-S Record Cleaning Machine
Use your God given ears.Political Correctness'.........defined
President of Club Polk -
Dirac is pretty finicky as a platform. The issues I get are the delays and trims are off (that should be easy part). It “centers” the stereo image way left. I was able to get it to center, some how, some way and it sounds great! But I can’t repeat it.
Somewhere on their roadmap is to allow manual adjustment of gains and delays.
Also, it doesn’t like my subs on a minidsp, when the biquad PEQ is on, it jacks up the delays to the limit of my AVR (25ms).
Overall I’ve been happy with Dirac but it’s inconsistency is challenging. I’ve always had my eye on ARC genesis. I love my anthem amp. Apparently ARC hasn’t been smooth sailing either.
