Forum Karma
xschop
1ea MW6500, rebuilt with aftermarket 6.8 ohm voice coil and and what I believe to be a factory flaw repaired of the voice coil clearance. Magnet reset accurately concentric with Pole-piece and Blue Locite used as adhesive. This one I also performed @Gardenstater's inner frame foam mod and the VanderPolk sub-spider foam mod. Updated to the newer lightweight dust cap and inverted. Small surround tear repaired with black butyl adhesive. And lastly, fresh butyl mat installed on the baskets and worthless frame tabs removed. This would be a good replacement for an MW6510 (IMO as it sounds accurate in my 8TLs) as well...
If you're in need, just chime in and I'll draw a name in the next week.
Chiming in, thanks
Easy peasy... Send me your address dromunds.Don't take experimental gene therapies from known eugenicists.
