New L800 for $2000 each
2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Polk Audio Factory Refurbished
Correct about refurb.
2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout. -
Question is, is A4L smart enough to send 1 left & 1 right?
They may not even know there a left or right...
Sound united had a surplus of right speakers from all their customers ordering left speakers- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
That's all they had left, right?SDA SRS 2.3TL's
SDA 2B TL's -
The "refurbs" are all those right speakers that didn't get to purchasers the first time.
______________
* I think it was rights that didn't make it onto the trucks...
Every single mixup leaves a pair of unmatched speakers.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
All the rights are behind a dryer, collecting dust.I disabled signatures.
Two wrongs don't make a right. But 3 lefts do!Gustard X26 Pro DAC
That has to be the dumbest yet preventable screw-up by Polk. SDA is your legendary speaker and you bring it back from the dead only to drop the ball on the packaging, labeling, SKU, and the ordering side here in 2019-2022?
I don't get it. Internal sabotage maybe?2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
I’m surprised to see their specs listed as only reaching down to 32hz. With twin 10’s I would have thought they would go a little lower.
With room gain you would see high 20s- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
They seem to go much deeper than their specs indicate.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
