6750 + RT-800
jspin
Looking to pair RT-800's with 6750 sub and two satellites for added bass. Since sub only puts out 50w and my receiver puts out 80w, should I connect RT-800 to "A" ports and 6750 to "B" ports of receiver for maximum output? Or would that mess with proper crossovers?
Thanks!
Thanks!
Using the A and B speaker connections should be fine, adjust the variable low pass filter, on the sub, so you hear a smooth blend between the speakers and the sub.
Welcome to the forum, by the way!
