Problema con mando a distancia
Hola, cuando subo o bajo el volumen con el mando a distancia, se queda sin sonido y debo apretar el botón OPT para que vuelva el sonido. ¿Qué debo hacer para que no me suceda? Gracias anticipadas
  • Hermitism
    Hermitism Posts: 4,320
    Spanish to English translation:
    Hello, when I turn the volume up or down with the remote control, there is no sound and I have to press the OPT button to get the sound back. What should I do so that it doesn't happen to me? Thanks in advance
    txcoastal1 Posts: 13,499
    edited February 2022
    Crishl wrote: »
    ¿Con qué producto tienes problemas? Dónde te encuentras
    What product are you having issues with? Where are you located?
  • gp4jesus
    gp4jesus Posts: 2,016
    Dondes vives tu?
    *all connected w/Premiere ICs
