Help Kim!
WhoopdieShiitWhoopdieShiit Posts: 2
edited August 2001 in Car Audio & Electronics
i was wondering if there was any way to get more out of my polk dx ten inch subs. what should i have the crossover set at frequencey wise? and how much power should i be able to feed them after they have been broken in? thanks
Brandon
Post edited by WhoopdieShiit on
  • SystemsSystems Posts: 14,998
    edited August 2001
    Brandon,
    If you goal is to obtain "MO - Bass" from your dx10's then build a
    Iso - push pull bandpass enclosure for these subs. If you want the design plans call us at 800-377-7655 and I will be glad to fax them over. This box has "gain" incorporated into the design so you won't have to play them hard to get a lot of bass from these woofers.
    Bass On!!
    Kim, Polk Audio
    Testing
    Testing
    Testing
  • sc0tty8sc0tty8 Posts: 69
    edited August 2001
    I got the same box setup for my 2-dx12's. Lets just say polk should invest into hearing aids....
Howdy, Stranger!
