L100's, take down, parts and crossover (possible upgrading).
'Tis the time of year that I've run out of fun things to do and I've been staring down the L100's and wondering what makes 'em tick... tock...
At the very least those nasty sandcast resistors gotta go as does that single electrolytic cap. Not much room in there, crossover just as wide as the woofer hole.
I'll be trying to reverse engineer the crossover.
So out came the tools.
Input wiring
Output wiring
The diapers
Input cup - da back (anyone can find the front!)
Tweeter front - there is a very thin film of foam that doesn't play well with disassembly. I'll need to find something to replace it.
Tweeter back
Da woof
Da woof back
Bezels
Cabinetry
Gigitty...crossover stuff
back
Image reversed to match the markings I've put there to reverse engineer this thing
Aaron
Enabler Extraordinaire
    msg Posts: 10,584
    Lol, the diapers
    mhardy6647 Posts: 35,440
    edited December 2021
    ALL212 wrote: »
    I mean... not to go all semantisist or anything -- but isn't that, technically, the front, and the... umm... back... is... you know, on the back. Of the speaker?
    B)
    VR3 Posts: 29,654
    I would definitely replace the two iron core inductors in the main signal path of the midrange. The rest are parallel
  • ALL212
    ALL212 Posts: 1,670
    VR3 wrote: »
    L4 and L3?
    I kinda have a working diagram now.
    Aaron
    VR3 Posts: 29,654
    the two with the iron going over top are directly in line with the midrange
  • ALL212
    ALL212 Posts: 1,670
    B)
    Why did I know as soon as I saw this post who it was! :D
    Aaron
  • ALL212
    ALL212 Posts: 1,670
    The electrolytic is just part of a impedance resonance compensation circuit...maybe leave that. Explains why they "cheated" on a relatively small (11uf) cap.
    L5, C6, R6 for the woof
    L2, C3 R3 for the tweet
    those 6 components seem to be the same circuit, just for their corresponding driver.
    Aaron
    SCompRacer Posts: 9,196
    Technically speaking, isn't this a drawback? :D
    ALL212 wrote: »
    pitdogg2 Posts: 27,663
    Technically speaking yes....
    Clipdat Posts: 13,101
    When I read "impedance resonance compensation circuit" my eyes glaze over and I start mouth breathing.
    Clipdat wrote: »
    You are the audiophile snake oil industry's kinda customer!
  • SeleniumFalcon
    Quantum snake oil, please.
    VR3 Posts: 29,654
    I quantum charge and cryo freeze all of my gear
    What did one energized capacitor say to the other?
    I can hardly contain myself.
  • ALL212
    ALL212 Posts: 1,670
    Note: Tweeter bezel is held on with magnets.
    Complications: Can't get too crazy on crossover components. I have a 4.5" hole to work through and that's it. I suppose I could get the chainsaw out...cut the bottom off and do as I please, then just glue glob it all back together. :s Not like I'm getting any warranty work done on this. :#
    So da plan is to get rid of all sandcast resistors and the two ugliest inductors (L3, L4) and replace them with economical air core inductors. I might "tip" that electrolytic with some extremely small Sonicap capacitors left over from a Dahlquist toy. These are .0082uf ...yep, decimal is in the right spot. If nothing else I'll feel like I accomplished something there. Maybe...maybe replace C1 and C2 but size is of utmost importance here.
    Values of inductors:
    L1 - 0.12 mH, .3 ohm DCR but done in circuit as pulling even one lead is damn near impossible because it's glued down tight.
    L2 - 0.6 mH, .7 ohm DCR
    L3 - 0.5 mH, .2 ohm DCR
    L4 - 0.3 mH, .2 ohm DCR
    L5 - 3.6 mH, .7 ohm DCR
    There are some air core inductors over at parts express that are reasonably close in DCR.
    Probably use Mills resistors.
    Better ideas??
    Aaron
    VR3 Posts: 29,654
    Check the mundorf L200 series Air core dcr. They were perfect for the l200
  • ALL212
    ALL212 Posts: 1,670
    roughly this... and if Polk doesn't want it here it can obviously be removed.
    Things in the squares are being replaced...or attempted to be replaced on the same board. Gonna be squeaky tight!!
    Aaron
    VR3 Posts: 29,654
    I wouldn't recommend posting current production schematics
  • ALL212
    ALL212 Posts: 1,670
    what schematic... B)
    Aaron
    VR3 Posts: 29,654
    Yeah, Polk is really awesome to let us openly mod their products and talk about what all we do.... Not many manufactures are down with that
  • ALL212
    ALL212 Posts: 1,670
    Edit on the inductor values
    L3 is .6 not .5
    Values are written on the board but covered by the component.
    Aaron
  • ALL212
    ALL212 Posts: 1,670
    And done! Still sound good in spite of my work. :#
    Aaron
    What's the first track you're gonna play through them after hot cross buns?
  • ALL212
    ALL212 Posts: 1,670
    Gangnam style I think…
    Aaron
    edited February 2022
    Nice! Then maybe after that go way back to some Who Let The Dogs Out and maybe even Macarena (bayside boys mix, of course)
    https://www.youtube.com/watch?v=zWaymcVmJ-A
  • ALL212
    ALL212 Posts: 1,670
    I’ll have to get out my reference level K-tell records and see how those play. Unless I can find my 8-track player…
    Aaron
    VR3 Posts: 29,654
    Baby shark
    Don't act like you haven't played that on the Grandes!
    VR3 Posts: 29,654
    Oh you know it
