Passive radiator out of phase issue. What's the best placement of passive radiator
So it seems front firing passive radiator will always be 180 degrees out of phase with main woofers. Do rear firing radiators sort of help with phase alignment.
Are there any other clever tricks to modulate out of phase play of passive radiators
    nooshinjohn Posts: 25,933
    It takes a special kind of stupid...
    VR3 Posts: 29,448
    Aye carumba
  • Unknown
    edited December 2021
  • BlueFox
    BlueFox Posts: 15,251
    I’m not sure how passive radiators work, so I looked it up. Nobody mentioned anything about them being out of phase. I can understand a slight bit of lag in the response, but certainly not out of phase.
    https://en.m.wikipedia.org/wiki/Passive_radiator_(speaker)
    It’s that Stephen King time of year again. Children of the corn are coming in from the fields....
  • Jstas
    Jstas Posts: 14,985
    Are you for real?
    It's physically impossible for a PR to be "out of phase". They would have to be active radiators to be out of phase and we call active radiators, drivers or speakers to the lay person.
    A passive radiator does the same thing as an enclosure vent but instead of being tuned for a specific frequency resonance to reinforce the bass response, a PR is weighted and fluid coupled to the active drivers in the common enclosure to reinforce low end frequency response over a larger range.
    Ported enclosures get loose and "farty". PR enclosure don't unless something on the PR failed like part of the suspension structure or there is an issue with the weighting or if any enclosure stuffing has come undone and is impeding movement of the PR.
    Expert Moron Extraordinaire
  • Jstas
    Jstas Posts: 14,985
    Ugh. I'm not dealing with this at 1 am on my phone.
    I'll educate you tomorrow from an actual keyboard.
  • Jstas
    Jstas Posts: 14,985
    You have no idea what you are in for
    xschop Posts: 5,198
    Someone posted a graph here back in the day demonstrating the frequency roll-off or dip when incorporating a PR.
    One thing's for sure, it's efficiency is directly related to how well your cabinets are sealed. The weak link is the factory tweeter gasket seals and the condition of the MW spider cloths I have found. Some are more porous than others. There is a white mold that has an affinity to the spider cloths and dust cap cloth cellulose material.
  • jbreezy5
    jbreezy5 Posts: 1,141
    This is a quick recap on how they work
    https://youtu.be/Ngj6HCfFnJo
    Spring analogy is pretty accurate. So looks like they play by themselves..not in ideal synchrony with main drivers.
    Nooshinjohn please remind your relatives and friends that inbreeding is bad.
    Based on the video you shared PRs are presented in a positive light. He demonstrated with the spring that a PR responds to slower/longer frequencies.
    How can something that derives its motion (PRs) from a separate active device (active bass driver) be expected to move instantaneously/simultaneously with the active device?
    In this regard, the problem remains the same whether the PR is located on the front, side, rear, bottom, or top of the cabinet.
    Am I understanding your question, correctly?
    Otherwise, you may be able to get the specific answer to your question by contacting Definitive Technology directly.
    Lastly, if you don’t feel you’re getting the SQ you are seeking with a PR in the system, you might consider acoustic suspension designs (closed-box / sealed cabinet) instead.
  • Not sure of the need for derision. Seems like a fair question to me and definitely something interesting to ponder over the first cup O joe. This guy on Audiogon seems to have an insightful answer and I hope he doesn't mind me posting it here:
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    treitz3 Posts: 20,019
    Is this gonna be another Polk classic thread? It sure does have all the right ingredients of one.
    Think black paint, porthole and the like.....Anyhoo, carry on. This should prove to be entertaining. I'll grab the popcorn fellas...
    Everyone cop a squat and get comfortable. I'll have my other half bring the adult beverages and finger food for later on when the gettin' starts gettin' good.
  • Gardenstater
    Gardenstater Posts: 4,785
    Was this the one @xschop ? You can see the notch in the output of the driver at the passive radiator resonant frequency, where it is dampened by the PR and the PR predominantly takes over.4cw4ff8sa7pi.jpg
    PS: I see this thread has been removed from "Recent Discussions". Cancel Culture at work?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Unknown
    xschop Posts: 5,198
    Yes, that was like it. Reason why I Power Ported my first CRS+ set as they took less power to achieve higher bass spl in those frequencies.
