Looking for locking angled nanners
muncybob
Found these. Can I do better in this price range?
https://www.amazon.com/gp/product/B00O3NTB28/ref=ox_sc_act_title_1?smid=A02211013Q5HP3OMSZC7W&psc=1
Yep, my name really is Bob.
While it may not be the answer you are looking for... bare wire is so much better than using cheap connectors- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
From a pureits' point of view I would agree, although I have never heard a difference myself. My Vandersteens do not have biding posts, so nanners are essential.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Why not install binding post? 🚀- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Bob I've tried to use those before from parts express. 2 of the 4 stripped when I went to tighten down the screw.
I hope you have better results. -
Installing posts would require modifying the back plate. Not sure I want to do that as it will probably affect resale.Yep, my name really is Bob.
