Using Polk components in a Baby Advent cabinet
laptop44
laptop44 Posts: 11
edited November 2021 in Speakers
Hello I had some spare Polk Monitor 10 parts and used the SL 2000 tweeter and one woofer and installed them in a Baby Advent cabinet. I was amazed on how well it sounded. Bass was tighter and the SL 2000 was an improvement over the tiny Advent tweeter. I am still using the Advent crossover and would like to know if I can use the Monitor 10A crossover instead. Are there and mods or anything I need to do ? I see there is a small bulge on one of the caps
    F1nut Posts: 52,011
    Where do I start......hmmm....let's just say what you've done is wrong on each and every level.
  • boston1450
    boston1450 Posts: 7,758
    You should TL them. Advent TL Baby Baby
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • Hansvelton
    Hansvelton Posts: 151
    Most Advents run the woofer full range, meaning, no low pass filter to roll off the highs.
    And of course, their woofers were fine for this, as they had a NATURAL high end roll off and sounded fairly good that way.
    BUT, your Baby Advents seem to have aftermarket woofers anyways...so.......
    The Polk woofer, on the other hand, requires a low pass crossover on the woofer, as it does not roll off in the same manner at all.........
    Refer to what F1nut said above........
    Might be a fun experiment, but doubtful it can deliver great sound.
