CRS+ / 2b crossovers / upgrade
boston1450
Upgraded CRS+ crossovers-binders-Larry's rings-baffles-speakon IC cable. I purchased these Nov 2015 & rec Dec 2015 & installed them. They sound fantastic then & still do now. All the info is pictured on original thread what's on them. In 2017 these were stored in spare bedroom as RTA15tl'd took over the roost. Last month I hooked em up & was amazed at the soundstage & the performance of them. The only reason parting them out is because of slight cabinet issue/condition which I knew when I originally purchased the speakers on eBay.... Pls look & read all notes on pictures below. Thx.... Crossovers & all wires. Binding cups & terminals. Larry's rings ( painted ). Speakon IC cord. Baffles designed by WMG. All for 150.00 you pay shipping (signed delivery-insured) to lower 48 states. PayPal FF or you pay PP%. Thank You for viewing thread....... Note To buyer only (at this time) .. I have RD0198 tweeters & MW woofers if needed for buyer @ 20 dollars each & I'm sure I have spare MW's too for this project.
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
by David WMG
Post edited by boston1450 on
Randy-Maine
by David WMG
Randy-Maine
by David WMG
Randy-Maine
by David WMG
Randy-Maine
by David WMG
Randy-Maine
by David WMG
Randy-Maine
by David WMG
Randy-Maine
by David WMG
Randy-Maine
by David WMG
Randy-Maine
by David WMG
NOTE: FYI-This states they were never installed BUT I think they may have been used before. Any question please ask here or PM me. Thank you
Post edited by boston1450 onRandy-Maine
by David WMG
PM sent.
^^^^ Pls correct me if I'm wrong.... To use these on 2b's - your existing wires should plug into this crossover-like they are now. You may need (or if you have) different MW's (6511's) I do believe.... You will probably need to remove your sl2000 or 194 tweeter your using now & install 198 or SL3000(I think). The passive ring will probably be different but all the rest should work just fine. I have 2b's loaned out to daughter so I can't look say for sure
Randy-Maine
by David WMG
Put me in line if he passes. Thanks2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
North Star Intenso Dac
Auralic Aries Mini Streamer
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
dkfreebird wrote: »Put me in line if he passes. Thanks
la2vegas was asking question about using these on 2b cabinets & all his PM's were answered. I think he was waiting to confirm....Randy-Maine
by David WMG
No worries. I’m in if he passes.2 Channel
Oppo 103
Pangea PC
boston1450 wrote: »^^^^ Pls correct me if I'm wrong.... To use these on 2b's - your existing wires should plug into this crossover-like they are now. You may need (or if you have) different MW's (6511's) I do believe.... You will probably need to remove your sl2000 or 194 tweeter your using now & install 198 or SL3000(I think). The passive ring will probably be different but all the rest should work just fine. I have 2b's loaned out to daughter so I can't look say for sure
Yes these should be plug and play on 2b's once you drop in the RD-0198's. The passive ring will need to be 12" on the 2b -
Thank you IvanRandy-Maine
by David WMG
Personally I would make longer leads for the laminated inductors for the 2b, get them monsters far away from the XO as you can. I put mine in the bottom of the cabinet about 14" from the XO.
Understandable for the CRS+ since your cabinet is much smaller. -
I'm also interested if they pass.
These are Pending/Sold thank youRandy-Maine
by David WMG
Please let me know if you have extra RD0198s for sale. Thanks.
These are sold. Thank youRandy-Maine
by David WMG
The eagle has landed...
Thanks Randy for a trouble-free transaction. Everything arrived safe and sound thanks to your stellar packaging ability.
That was a very generous all inclusive package that you offered to transform my 2B's. Well almost, all I need now are some of those $600 spikes that Joey is pondering on his thread.
Your very welcome Jose. It was a pleasure talking to another Polkie. Enjoy your project & I wish you the bestRandy-Maine
by David WMG
