Premium aftermarket SDA-1C wiring harness?
PolksTillIDie
in Speakers
Finally getting crossovers, inductors, binding posts, interconnects (all premium) from westmassguy probably next week. Hoping for quite a bit improved sound over the already great sound I was getting. While I've been waiting, it occurred to me that with these improved components, I've left something out: the wiring harness inside the cabinets.
Anyone know of any replacement wiring harnesses available with OFC or other premium materials?
Polk SDA-1Cs with RD0194-1 upgrade tweeters, SoniCaps, Clarity PX, Gimpod boards, Cardas BPs, Erse inductors, Canare 4S11 IC; Michi P5; Yamaha M-80; Yamaha CD-S1000; Oppo BDP-95; Sony UBP-X800M2; EverSolo DMP-A6; Topping DX-7 Pro +; Technics SL-1400 with Ortofon 2M Bronze PnP; PS Audio Dectet; AudioQuest Red River ICs; AudioQuest NRG-Z3 PCs; RapcoHorizon High Def High 413-Strand 10AWG Speaker Cable; Auralex Isolation Pads
The world is your oyster, but you're making your own. Many of us have, I did my 2.3tls. yours would be much simpler than mine were. The real fun is bending those little connectors that snap into the wire block. Them little muggers hurt your fingers.
I believe they make a tool for those molex connection blocks
Bending the connectors?
I just use a set of plyers? Shouldn't need anything special.
To remove them, it is easier with a removal tool- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
