Weird RF interference issues
So over the past 2 weeks I'm having a series of issues with my garage door opener, cable TV and cable internet. The range of the garage door remotes has dropped significantly. Sometimes standing right next to the door the remote does not work and sometimes it does. My cable internet downstream is close to a gigabit but upstream is spotty between 1 to 4 megabits when I should be getting 20 up. Occasionally it will burst up to 20. And on my cable TV I have a single channel at 309MHz that is consistently pixelated while all other channels are fine.
I've checked signal strength and SNR levels on the cable modem which are all within spec. I checked the cable TV channel that is pixellated and the signal strength is same as other channels. I had the cable tech out who checked the levels and assured me everything is checked out.
And for the garage door I've tried turning off every other circuit in the house to isolate devices that may be causing interference. No dice.
I am scratching my head as all this happened in past 2 weeks. Any suggestions?
  • BlueFox
    BlueFox Posts: 15,255
    I had the garage door issue. Sometimes I had to get out of the car, and stand next to the door before it would open. Turned out the problem was the battery in the remote. After replacing it everything was fine.
  • anonymouse
    anonymouse Posts: 2,818
    My issue is sadly not battery related... I did change that in one remote, but I'm having it with the built in remotes integrated in my SUV and Truck as well. All remotes are intermittent
    VR3 Posts: 25,721
    Is your right modem out of phase to the left?
    - Not Tom
    "No, that's silly talk. Dude, you can't possibly be this audio dumb so quit the act." - Doro
  • jdjohn
    jdjohn Posts: 2,405
    I would not rule out paranormal activity.
    txcoastal1 Posts: 12,283
  • skrol
    skrol Posts: 3,163
    Have you installed any cheap LED bulbs lately? I had a similar issue with my garage door opener. It turned out to be caused by the cheap LED light bulbs that I installed to replace the incandescent bulbs. The bulbs have a little switching power supply built into the base. If it is a poor design, it can be electrically noisy and cause interference.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • odcics2
    odcics2 Posts: 107
    Anyone on your electric line could have installed something causing interference.
    For example, if a neighbor installed a noisy dimmer, it's like YOU have it in your house!
    pitdogg2 Posts: 20,999
    I had the same issues with a chamberlain garage door opener. They put new boards in it and still only one would work out of my two doors. They tried to blame all kinds of stuff, but I asked why one worked fine and the other wouldn't? Both on the same garage, both installed the same day, same opener on both. They couldn't ever answer. No neighbors to blame, no LED's nothing had changed just 8months in one quit. In the end I think one opener was affecting to other. I got fed up and bought two new openers and both worked and still work. Never had a conclusive finding.
  • anonymouse
    Thanks all. I turned off pretty much every circuit to eliminate the possibility of one of my other bulbs or devices causing interference. It could be a neighbor. And yes thus is a craftsman branded Chamberlain opener.
  • BlueFox
    Sounds like you need to enclose your house in a grounded wire mesh in order to determine if the cause of the problem is external or internal. Good luck. :)
  • skrol
    skrol Posts: 3,163
    BlueFox wrote: »
    Faraday cage the house
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol
    skrol Posts: 3,163
    Are you having any issues with lights flickering. If so it could be a power line issue that your power company can look into.
    I was having high intermittent voltage issues. The secret was to say that the lights were flickering. They monitored a while, then made some adjustment to lower the voltage.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • anonymouse
    skrol wrote: »
    Thanks. Not that I have noticed. Will keep an eye out.
    tonyb Posts: 32,682
    edited September 2021
    Have you changed out any questionable cables ? I might change them out one by one, even for a lower quality cable you might have laying around just to see. Also exchange the cable box for a new one, they should do that for free.
  • anonymouse
    I am a TiVo user. My TiVo had been working flawlessly for 4 years. And it's only that channel affected... 187. Today I took the tivo upstairs and hooked it to 2 different outlets including the one I connect my modem too. No improvement. Entirely different cables.
    I think I will rent an extra X1 box to see if that does better. If it does then I will try to get a new cablecard for the tivo. Last time it took me 3 tries to get a working cablecard from Comcast.
  • anonymouse
    Comcast sorted this yesterday. Something on the street side was causing all the issues. My cable modem now shows 3dB higher levels, connecting solid, cable fixed and the garage door works again. All related to cable. Amazing but if it wasn't for a diligent line tech none of this would have been resolved. The Comcast tech that came to my house a couple weeks ago was insistent that there was no issue on their side and that my modem was weird. Now let's see if I can get Comcast to remove the $100 they billed me for that unproductive service visit.
  • invalid
    invalid Posts: 805
    Doesn't seem like they should charge you anything at all, seeing how it was on the street side and nothing to do with your side or equipment.
