Audioengine B1
My Marantz 6005 has become a bit finicky and I want to go back to something w an app and volume control for my iphone. The Marantz app is useless unless I am completely missing something. Any feedback on the B1 and / or one laying around you would like to sell? Thanks and Go Bears!
  • verb
    verb Posts: 10,176
    I landed on the B1 for the spare room upstairs, after returning the Auris BluMe twice due to issues (connectivity drops, forcing me to re-connnect, annoying). The B1 is pretty decent, in terms of connectivity no issues, and the latest AptX codec, sound quality is pretty good! I stream Tidal from my iPhone to it.
  • kevhed72
    kevhed72 Posts: 5,165
    Really....how does that work out for you? Funny I tried the Auris awhile back and couldn't return it quick enough. Do you just use the Tidal app on your phone straight to the B1 then B1 to your DAC?
  • verb
    verb Posts: 10,176
    Yep for me the Auris was, well, didn’t work out.
    I run Tidal off my iPhone to the B1, direct to the preamp. I suppose you could run it to a DAC, not sure if you could disable the built in DAC.
