This amplifier manufacturer says it uses an atomic reactor
invalid
mmm-hmm.
Replete with G-Spot for that glass FET
what is that 15w into 8ohm?
A good amp doubles power from 8 ohm to 4 ohm, so I would assume this amp increases its power from 16 ohm to 8 ohm. Then again, an 8 ohm load might make the atomic fusion reactor unstable.
Three 20 amp circuits. -
Hmm... unstable fusion could cause a problem with Underwriters Laboratory certification...
The real question is why is this thread in the Car Audio section?Lumin X1 file player, Westminster Labs interconnect cable
Based on the copy in the attached image, it's meant for car installation.
I mean, it's on the pathway towards... Mr. Fusion.
That's why I posted it in the car audio section
Sorry, didn't read all the text. Love the part that says 'For small vehicles, a rooftop mounting rack is available.' LOL
For $30,000 to $40,000 a car should be included.
Maybe the car can run off the atomic reactor as well as the amp.
Heated seats. Love those when it's 95 outside. They should add the benefits of birth control being mounted under the seatGustard X26 Pro DAC
