This amplifier manufacturer says it uses an atomic reactor
    mhardy6647 Posts: 35,166
    mmm-hmm.
    Replete with G-Spot for that glass FET :#
    pitdogg2 Posts: 27,187
    what is that 15w into 8ohm?
  • BlueFox
    BlueFox Posts: 15,250
    A good amp doubles power from 8 ohm to 4 ohm, so I would assume this amp increases its power from 16 ohm to 8 ohm. Then again, an 8 ohm load might make the atomic fusion reactor unstable.
    Hmm... unstable fusion could cause a problem with Underwriters Laboratory certification...
  • BlueFox
    The real question is why is this thread in the Car Audio section?
    Based on the copy in the attached image, it's meant for car installation.
    I mean, it's on the pathway towards... Mr. Fusion. :|
  • invalid
    invalid Posts: 1,509
    That's why I posted it in the car audio section
  • BlueFox
    Sorry, didn't read all the text. Love the part that says 'For small vehicles, a rooftop mounting rack is available.' LOL
    For $30,000 to $40,000 a car should be included. :)
  • invalid
    Maybe the car can run off the atomic reactor as well as the amp.
    audioluvr Posts: 5,977
    edited September 2021
    Heated seats. Love those when it's 95 outside. They should add the benefits of birth control being mounted under the seat
