SDA1 price check
dragon1952
in Speakers
To start with I know nothing about SDA's. There is a pair of SDA1's in the local craigslist that appear to be in very good shape for $350. Is that a decent price?
Describe SDA1 please.
2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
Original SDA 1
Personally it might be a bit high. That being said I had the SDA 1 signatures. Basically same speaker but ports plugged and brass plaque over. Need common ground amp and not a bad speaker. Remove the fuse for the dimensional tweeter for a less phasey sound. The SDA tweeter can be fun but it is just as much distracting as well.
Ymmv -
Thanks. Not really in the market anyway but thought if they were a good deal I might go for it ;^ )2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
