How to unsubscribe from a thread?
I posted to 2 that get 10-20 posts a day. Most of the content I don’t care for.
Thanks. Tony
*all connected w/Premiere ICs
  • mdaudioguy
    mdaudioguy Posts: 5,165
    Here's a screenshot of a thread that is NOT bookmarked. See that little symbol that's circled? If you can see it, you're NOT subscribed/bookmarked. If you touch/click it, it disappears and you ARE subscribed/bookmarked. You simply have to be a magician and find the invisible symbol, touch or click it, and make it reappear!
    This is normal, right??
  • BlueFox
    BlueFox Posts: 15,251
    Invisibility seems to be a theme with this software.
    pitdogg2 Posts: 27,065
    Or go to settings in your profile and unclick everything.
  • mdaudioguy
    I had been to that page several times and couldn't figure out how to change anything...
    I just now realized I needed to slide to the left to see the checkboxes on the right. 🤦‍♂️
