s35 w/amp??
I have the emotiva xpa3 and recently bought the center s35. Just wondering if you guys would use the amp or receiver for that speaker? I know some have mentioned you cant enough power and it just depends on how loud you play them?
receiver- marantz1607
thanks
Marantz 1607 - Polk S60 - S35 - Emotiva XPA-3 - Polk DSWPRO550wi
    F1nut Posts: 51,959
    edited August 2021
    It's a 3 channel amp, of course you should use it for the center.
    That's not the reason. Higher powered, high quality amps make the sound better at lower volumes. Note, I said high quality.
  • BigA524
    BigA524 Posts: 63
    If the marantaz doesnt have a pre out for the center is there another way to hook it up to the amp?
    unless im missing the out?
    pitdogg2 Posts: 27,245
    Without preouts you cannot use the amp and receiver as you want. That model only has preouts for front channels
