Additional garage at Verb's house!
So this new may draw a bit of controversy, but I pulled the trigger just today! Cambridge Audio EVO 150!
Being in the garage, I wanted to keep the footprint of the audio system to a minimum. Flat panel screen (I can fit a 65" where I plan to put it, 2.1 channels max, bookies, and a wireless sub)
This guy seems to fit the bill. I've been very happy with my CXNv2, and 851N to date. This guy will be used mostly for streaming Tidal, and I can connect the TV via HDMI, and has a sub output.
It boasts 150 WPC (Class D, I hear the love coming!), but has pre-outs so if desired I can hook up a power amp in the future.
Plus plenty of other connections, XLR, 12v triger, even a phono (haha, yeah right TT in the garage)!
Very excited, ships on Monday!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
That will rock in the Garage Cave! Ain’t no critical listening going on in there anywho!
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
Nice unit.
Did you get a bonus or did your wife go to Vegas again?
That unit does a lot of things.Most people just listen to music and watch movies. I EXPERIENCE them.
Thanks Dog! Yeah footprint was most important, but the reviews out there so far are pretty good. Certainly man cave worthy!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Nice unit.
Lol just some planning in the budget! And the Mrs approved!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Decided to give Analysis Plus speaker cables a try. Silver Oval 2's. They'll be in-wall, but will have access ports (closed out with a single gang blank wall plate) along the routing to facilitate removal if needed.
Made in Michigan too!
Didn't know they were made here. -
Agree PVC hoses are junk. Rubber is the only way to go.
The PVC and urethane hoses last way longer than rubber but they are more suited to use as plumbing rather than access lines. In other words, if you're going to plumb air drops with either quick connect points or reels, the PVC or urethane hoses are better to use for the feed lines going to those access points.Expert Moron Extraordinaire
PVC or urethane hoses are like pipes when I'm working outside in the cold, rubber is definitely better to work with.
I do not disagree with John, they would work great for that. My problem is I've bought more than one PVC hose that had more holes than swiss cheese brand new out of the package. When it gets cold here in Illinois the PVC hose like you said is stiff as a board. It didn't roll back on or off the reel worth a hoot.
My last garage l ran a copper air line around the top of my garage and had drops coming down to quick connects for tools. What can I say I like to sweat/solder copper😉 I had a bunch of copper left over from replumbing my house so I thought that would be a good use for it. -
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Decided to go with some bookies for now in the garage. L200's!
Brick work is almost done. Been so rainy here as of late so slow progress.
Looking good! Your dog is looking at you funny.Gustard X26 Pro DAC
For sure! Walter is wondering what the heck is daddy looking at!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Id sell that plywood while it still retains some value…Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!!
What will you do when it is done? What a project!
BTW, you seem shorter in your posts.
Hey brother! Been crazy at work, and lost my brother due to Covid. But, time is a healer for sure.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Looks great......a large project for me is staking the tomatos
Very sorry to hear that Verb.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream
Prayers sentengtaz
Very sad news. :'(
Prayers sent to the family.Speakers: Polk Lsim, ATC SCM19 v2, NHT SuperzeroSpeaker Cables: DH Labs, Transparent, Wireworld, Canare, Monster: Beer budget, Bose ears -
Thanks guys. It’s been 6 months now but still stings when I think about it. I think about Rob every day. I was a total wreck back then. But now, with time, better.
I posted about Rob a few months ago, felt better in doing so, especially after the outpouring of love and well wishes. And now with yours as well. I really appreciate it.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Brick work nearly done!
Wow no update since July! All the drywall is in, electrical, gas line, and air lines all in. Attic ladder installed. I had them put some plywood flooring in the attic for storage too. Will post pics soon! Mudding and primer next week. Garage door install after that! Getting closer!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I did pick this up a few weeks ago
Gonna consolidate all of my Craftsman boxes (total 3) into this beast! Special edition Snap On 100th Anniversary Harley (matches my Softail)! Local, I still had to hire a flatbed to haul inn home!
What a magnificent looking tool box!! Congrats to you and it should look right at home in your new garage.
Sadly my one and only tool from Snap On is a utility knife. -
Great looking box!Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream
Beautiful tool box. I have a 883engtaz
Thanks fellas. Never thought I'd find this box in such great condition, and local!
More pics of the garage.
Attic Door installed.
Breezeway and Atrium connecting the old and new garages.
Mechanicals installed for the furnace.
