bi-wiring polk 800i's
gdockery
gdockery Posts: 1
just bought rt800i's,they sound great with lots of bass.please advise what gauge wires would be best to bi-wire for a little more treble.new to this scene.
Post edited by gdockery on
  • Norm E. Dickey
    Norm E. Dickey Posts: 36
    edited May 2002
    I use the same gauge for the high as I do for the lower freq, although some people claim that silver cables are better for high freq in biwire situations, I haven't auditioned them and can't say.
    My choice is 12 gauge. The higher freqs travel relatively close to the surface of the cable (ie 10k hz travels at a depth of about 0.66mm for copper wire) this is called skin effect. The larger the circumference (not diameter) the more the frequency carrying area for the higher freqs.
    Cables are components themselves, different constructions can have a different sound.
    Welcome to my home, enter of your own free will and leave a bit of the happiness that you bring. -D
  • gidrah
    gidrah Posts: 3,046
    edited May 2002
    And NormO was the nameO. Good job. I agree, I just didn't know why.:D
    Make it Funky! :)
  • juice21
    juice21 Posts: 1,866
    edited May 2002
    here's a thread i started awhile ago when first bi-wiring my rt800i's:
    on bi-wiring
    good luck, and welcome to the forum...:D
