Aries Mini: Recommend a USB DAC Upgrade
Dr_Wu
I know there are some Polkies who have and may still have a Mini streamer. So far, I've only used the onboard DAC. It's fine, but you know how it is: can I wring more SQ out of it? Already using a Teradak LPS, and power cables are solid. Assuming a decent USB cable, any suggestions in the $500-$1000, and $1-1.5k ranges? Tidal HiFi for now. Thanks!
For the money, the Shunyata Venom is hard to beat for a usb cable. Yes there is better but for around $100, its a solid cable.
On my mini, a W4S recovery made a big difference on the usb chain. -
Thanks, erniejade!
