Looking for epoxy recommendation for securing older Polk Audio Monitor speaker magnet
Orcbolg
Orcbolg Posts: 7
edited June 2021 in DIY, Mods & Tweaks
Hello,
It has been awhile since I've been on the Polk discussion board. Apparently the board has gone through several updates since I was last active on it. I am looking forward to upgrading my Polk Experience here.
I am currently looking to figure out the recommended epoxy to secure the magnets in my small Polk Audio Monitor speaker collection. I have reviewed several threads here and online on the subject, but I wanted to get a solid response on a current epoxy product to use since there are so many varieties out there that others have experienced. The main reason I am asking is I am preparing to move at a future date, and I do not want to have my small Polk speaker collection misalign the magnets during the process of transporting them. I look forward to the informative answers.
I currently have the following Polks...
M4 w/Peerless tweeters (latest pickup)
M5JR+ (my first Polks, bought @HickamAFB Hawaii in 1990)
M7
M7 Series2
M10 w/Peerless tweeters
M10A
    audioluvr Posts: 5,432
    edited June 2021
    Powergrab ultimate
  • Orcbolg
    Orcbolg Posts: 7
    Now is there a suggested prep before you use the adhesive needed before you use it on the magnet assembly? Like wipe/swab the area with alcohol to clean it before applying?...
  • ZLTFUL
    ZLTFUL Posts: 5,640
    Never hurts to have a clean surface when using any adhesive/epoxy.
    pitdogg2 Posts: 24,559
    When transporting lay them on the backs. You can also short the binding post with short wire or cable.
  • Orcbolg
    Orcbolg Posts: 7
    Good info! Did not think to short the binding posts together when transporting them. Just curious about the reason for that?
    Orcbolg wrote: »
    Keeps woofers from free bouncing as much. You're using the magnet, voice coil to lend some support.
  • Orcbolg
    Orcbolg Posts: 7
    I was figuring it was something along those lines due to shorting them together at the posts. Helping to stabilize the speakers is a good thing...Thanks for the reply...
    F1nut Posts: 49,794
    I'm back to preferring JB Weld.
  • skrol
    skrol Posts: 3,337
    Good, that is what I used.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • MotoMoto
    MotoMoto Posts: 4
    I use this stuff. Nice and slow to set up and doesn’t ‘flow’ as it hardens. Hard after 1 day, really strong after 3 days. Can be smoothed out with a wet (water) finger.
  • Orcbolg
    Been occupied with other items including family. Glad to know there are more options to consider...I have experience with JBWeld I've used with other projects but the PC-7 looks promising too...more research on the products until I am satisfied to commit...
  • ddog
    ddog Posts: 230
    What is the reason we don't prefer the PowerGrab Ultimate anymore?
    edited October 2021
    ddog wrote: »
    Some felt the bond was not good enough on metal.
    I've used it on a few drivers as it was much easier than JB weld.
    My thoughts were that it would hold good enough to keep the magnet from shifting better than if nothing was there.
    Either way dropping a driver I feel all bets are off.
    txcoastal1 Posts: 13,132
    The good stuff is by the black paint
  • skrol
    skrol Posts: 3,337
    Which black paint sounds best; flat, satin or gloss?
    Stan
    Main 2ch:
    HT:
    Other stuff:
    Depends
    Carpet, hardwood, subfloor , concrete??
    Wall coverings, windows??
