schematic for surround bar SDA
Gene_1950
I picked up an old surround bad SDA at a yard sale. got it working fine after replacing two pushbutton switches; connect a blue-tooth receiver then connectedd my iPhone. great sound but no volume control; the up and down buttons do not work. really would like to finish this project but have no schematic.....Gene
Best Answer
Hi Gene,
Do you know the model number of the bar?
Answers
Surroundbar SDA Speaker; S/N AM180702130; LOT 3123083
Cheers, Gene -
To go into this thing deeper...it appears the up/down volume have no effect. Also the max volume I can get out of it does not "rattel" the windows...sound is clear and not distorted......Gene
I'll see if the serial number can be linked to the model number.
That is a SurroundBar SDA IHT a very early (non-digital, non-Alexa equipped) version.
so is there a wiring diagram available?
I'm afraid not, sorry.
