Resistors Stock Wattage SDA SRS 2 1987 Pin Blade.
VSAT88
VSAT88 Posts: 1,325
edited May 2021 in Vintage Speakers
Hello. Does anyone recall what the wattage rating of the stock resistors are on the 1987 Pin Blade SDA SRS 2. Thanks.
    F1nut Posts: 52,011
    Standard was 5 watt. Replace with Vishay-Mills 10 or 12 watt.
  • VSAT88
    VSAT88 Posts: 1,325
    Yes, next question was if we were still using Vishay-Mills. Thanks @F1nut, again.
