Resistors Stock Wattage SDA SRS 2 1987 Pin Blade.
VSAT88
Hello. Does anyone recall what the wattage rating of the stock resistors are on the 1987 Pin Blade SDA SRS 2. Thanks.
Standard was 5 watt. Replace with Vishay-Mills 10 or 12 watt.Political Correctness'.........defined
President of Club Polk -
Yes, next question was if we were still using Vishay-Mills. Thanks @F1nut, again.
