SDA 2B or 1C for large space?
joebass3
joebass3 Posts: 311
edited April 2021 in Vintage Speakers
Seems like the 2B's are highly regarded by CP members, and generally get the nod over a set of 1C's. But what about in a larger room? Would the bigger 1C's with more drivers fill the space better?
My family room is about 20' x 20" with a high ceiling and I know it is far from being in ideal music room. I recently decided to get some vintage SDA's and found a pair of 1C's locally. They will be doing double duty for music and home theater. I connected them to see how they looked and to make sure all the drivers worked properly, and then completely stripped them down to do all the mods. Everything is complete (crossovers, hurricane nuts, sonic barrier, etc.) and they just need to be re-assembled.
I see a post a couple of days ago from VSAT88 (thanks!) in the SDA speaker deals thread for a pair of 2B's at an amazing price, and there are now sitting in my house. The price was too good to resist.
So now I'm stuck with a choice. Which to use and which to sell? If I tried to sell the 1C's, I'd never recoup the money I've spent to mod them. Leaning towards just rocking the 1C's, but looking for suggestions from those of you who have owned both.
  • Emlyn
    Emlyn Posts: 4,804
    For a 20 ft by 20 ft space I'd stick with the 1Cs. You could consider going up to one of the SRS models too. :)
    I used the smaller SDA speakers in smaller rooms and sometimes with a subwoofer.
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,805
    Keep both sets and move them in and out of your room because it will satisfy your curiosity which ones sounds the best (to you). Then you could sell one set, if desired.
    Harry / Marietta GA
  • joebass3
    joebass3 Posts: 311
    Emlyn wrote: »
    The SRS option was quickly dismissed by my wife! Even took her some time to warm up to the 1C's 😀
  • joebass3
    joebass3 Posts: 311
    That's a good idea. Since I have the 1C's in pieces, I'll set up the others for now and see how they sound.
  • Gardenstater
    Gardenstater Posts: 4,799
    The only problem I see with this is that you will have to modify the 2B's as well, to do the comparison properly. Have fun! :)
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    F1nut Posts: 51,931
    IME, the 2B modded to TL is the better balanced speaker with better tone. They would have no problem filling your space.
  • joebass3
    joebass3 Posts: 311
    edited April 2021
    I connected the 2B's today and also installed the B&K amp that I recently purchased. The 2B's sound damn good even in there stock form! They are replacing a pair of RTA 8T's that were connected to my Denon AVR, so obviously it's an improvement.
    So I guess my next step is to button up the 1C's and give them a listen. But since most on here feel the 2B's with the TL mod are the way to go, I think the 2B's might be staying.
    Only problem is, if I sell the 1C's I doubt I could recoup the cost of the speakers plus the money invested in the mods. Would it make sense to strip the new caps off of the 1C's and use them for the 2B's, since most of the values are the same? Or just sell them advertised as fully modded? I have a total of about 600 in them.
  • invalid
    invalid Posts: 1,512
    I would swap the caps and use the 2b's and sell the 1c's. The 2b's are the better sounding speaker especially with the mods.
  • motorhead43026
    motorhead43026 Posts: 4,024
    I have yet to hear the 1C’s but I do enjoy my fully rebuilt and fully modded 2B’s.
    – Kevin Alfred Strom
    audioluvr Posts: 5,982
    I've owned both but haven't heard the 2Btl's and I don't know of anyone here who have A/B' d 2Btl's and 1C's in the same room with the same equipment. I would bet money you'll like the 1C's better. Build them both and do the side by side review. We'll help you sell the ones you love the least. ;)
  • pkquat
    pkquat Posts: 748
    I do not have 2B's or CRS+, but I do have 1C's, modded 2.3TL's and some 1.2TL's. Base on the 1Cs and the 2.3s, I think the comment about the CRS+ having a bigger sound stage is due to the speaker spacing. The 2.3 and 1.2 have a similar sound stage. Both have a larger sound stage than the 1C's. I have heard the SRS2's also have a larger sound stage and more bass. They are basically a 1C in a larger cabinet (and larger PR?) with the same speaker spacing as the 2.3 and 1.2. People also really love there modded SRS2. Based on this I think the sound stage will be the same for the 2B and 1C. Provided you have good space on the sides of your speakers, you could go with wider spacing, so if the larger series is not an option, maybe a set of CRS+ could be in your future. The CRS can be TL modded to use the RD0-198 tweeter.
    The 2B with the TL mod is highly praised in this forum, but depending on the day, there are comments that the 198 tweeter is not much better than the 194, to the 198 tweeter sounds much better. I do think the 2B hits a synergy point on size and design for 2 channel listening based on a number of peoples comments. The 1C's will provide more bass, and I think fill your room more for HT. The 1C's definitely rock, and IMO still do great on imaging. I would finish building the modded 1C's and break them in. See how things sound. See how you thing the modded sound compares to the original and then see how you like the 2B's.
    My guess based on comments throughout the forum is that in the end a modded set of 2B's will sound slightly better than the modded 1C's. If you like good bass rumble for HT, I feel the 2B's will not do as well unless you get a sub.
    On a side note, I have not yet modded my 1C's because I want to figure out a crossover to use the 198 tweeter. I have been told to give that dream up because a modded 2B sounds near as good as a TL modded 2B, and that I would not notice much difference. :neutral:
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    I have 2Btl's and upgraded 1C's. Using the same source amp, the 2's had better imaging then the 1c's. The 1C's could go louder but they didn't sound better. Sold the 1C's and kept the 2B's.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • TroyD
    TroyD Posts: 13,124
    Heresy to some perhaps.....but I think the 2B's and the CRS's are the sweet spot for SDA. I don't have a ton of experience with the 1C's but never warmed up to them to be honest.
    BDT
  • Navy_Goat
    Navy_Goat Posts: 375
    I also have both. Modded in the same ways. The 2Btl sound better to my ears also. The 2Btl sit in my office right next to a pair of Zu Audio Omen. I listen to the 2B much more often than the Omen. The 1C have been relegated to the closet. The 1C were out for a few weeks when I modded my living room speakers and they sound good for sure, just not as good as the 2Btl.
    SDA SRS 2.3tl, SDA 1C, SDA 2B (TL mod), Reserve 200
  • VSAT88
    VSAT88 Posts: 1,314
    edited April 2021
    2B vote here. Got em, modded em, (inc. TL mod.) room size 7.5 x 14.9 x 23 and I can turn up AC/DC For Those About to Rock so loud that it will nearly run you out of the room. Plenty of speaker for my size room for sure. I have not heard a 1C to be honest but I do have many other speakers like a set of Snell C/V's and to me the SDA 2B sounds just as good if not better in some ways. Happy for you getting those speakers BTW. They went to a good home !
