Calling experienced pool owners
1235»
  • rooftop59
    rooftop59 Posts: 8,120
    That’s awesome! You use gas heat?Hopefully we’ll get our heat pump repaired and be swimming soon.
    Anyone have any recommendations on a robot vacuum under a $1000, preferably way under?
    With our mains not cut in yet the filter isn’t clearing the water very quickly through the skimmer, although I’ve been brushing a couple times a day to stir up the dirt. Thinking a vacuum could help with this.
    we bought one very similar to this (the in store version is slightly different). We used it for one full season so far and its been great!
    Game Room 5.1.4:
    Bedroom 2.1
  • Willow
    Willow Posts: 11,258
    Yes we have a gas heater. I did turn it way down at the beginning of the week as just like Doc, we got a dusting of snow. But we need to keep at least 21c to keep the salt water generator going. Vacuum will certainly help as will getting your chemicals in check and maintained.
