Upgrade receiver but lose Amp?
ArsenalFC
ArsenalFC Posts: 50
edited March 2021 in Electronics
Hey folks,
I've always appreciated your input on all things audio and you've given me great advice over the years.
My current set-up:
Receiver: Pioneer SC-61
Amp: Krell S-300i (Run in 2 channel amp mode for L+R)
L+R: GoldenEar Triton 2
Center: GoldenEar SuperCenter XXL
Surround: Polk S10 (a weak spot, need to upgrade. I have RTi 4s I could swap in here)
Sub: SVS SB 2000
So, the receiver has served me well over the years. But, it isn't capable of Atmos. I'm 100% sure my wife wouldn't appreciate me dropping what is necessary to upgrade the receiver (after all, it works just fine). But, I could consider selling the Krell (and the Pioneer for whatever little could be recouped from that) and end up with a $1000 - $1500 receiver.
Any thoughts on old receiver + amp vs new receiver? Opinions on other options are welcome as well!
Sidenote" I can't seem to shake the feeling that my system "leans" right. I've tried different configurations, wired directly from the receiver and now from the amp and it still seems to lean. It might be the room. But I wonder if it may be the receiver which is another driver in thinking about upgrading.
  • ArsenalFC
    ArsenalFC Posts: 50
    The Triton 2s aren't incredibly difficult to power, but I'm sure like all speakers they'll definitely sing more with their own dedicated amp.
  • rooftop59
    rooftop59 Posts: 8,121
    Something like a Cambridge, nad, or anthem in your price range might work. The little Cambridge I have in the bedroom. Definitely the most musical avr I’ve had...
    Game Room 5.1.4:
    Bedroom 2.1
    F1nut Posts: 51,771
    You're thinking about giving up an excellent AVR and power amp just to get ATMOS? Are you crazy!?!
  • ArsenalFC
    ArsenalFC Posts: 50
    Now this is the type of feedback I came here for! Thanks guys. So a $1000-1500 AVR simply isn't an upgrade over status quo? I suppose it's not just Atmos, but that's part of it. The old dilemma of asking for both music and movie strength. Hard to do both well.
  • Emlyn
    Emlyn Posts: 4,708
    Regarding the perceived "lean" in room response you can try a sound pressure level meter or an app on a smartphone to double check decibel levels for each speaker manually.
    F1nut Posts: 51,771
    ArsenalFC wrote: »
    You could look into getting a 2 channel pre-amp with an HT pass through/bypass, then get an ATMOS capable AVR.
