Two or More Bell'o Glass Shelves Only for Existing Rack
CGTIII
Existing shelves are 19 7/8 inches wide by 13 3/4 deep.
Deeper would be OK.
Preferably clear but others considered.
Deeper would be OK.
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc.
Go to a local glass shop and have them cut. They can get good quality tempered glass.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
I have a glass door from a HT rack and a glass shelf from a DLP TV you can have....
Thank you but looking for audio rack shelves only.Expect that there will be bumps in the road. Choose to not let them rattle you.
