Original Model 10 fuses
HI, Just inherited a pair of original Model 10s, but they don't have the fuses. I need to know what fuse size for both the LF and HF. Thanks!
    pitdogg2 Posts: 27,578
    My speakers had 1amp 250v fast-blo for tweeters.
    I can only guess at what the woofer would be, I'll let others help with that.
  • Gardenstater
    Gardenstater Posts: 4,858
    Do yours look like this? If so, apparently it is 2.5A for the Low:
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • karma_samten
    Yes that is mine! Ok. so now we now the LF. Thanks.
  • karma_samten
    Oh, so would the voltage be the same for the LF? 250V? Thanks.
    F1nut Posts: 52,165
    Yes
  • Gardenstater
    Fuses protect against over current, not voltage, so as long as the voltage rating is as high or higher than the application voltage you will be fine.
    In this case, 125V fuse would be just fine as well.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • karma_samten
    Got it. Thanks.
