Polk RTA 12 - what are they worth?
Made in 79. I bought them slightly used in 1982. The rosewood vinyl has been covered in black vinyl, otherwise they look nearly new. What are these worth? Thanks!
Best Answer
  • Jazzhead
    Jazzhead Posts: 526
    Answer ✓
    The crossovers on the original version cannot be modified to roll off the outer drivers. That's why Westmassguy came up with the idea to do something sonically similar by using damping material (Black Hole 5 or Sonic Barrier) to overdamp and "absorb" some upper frequencies of the outer drivers (so the drivers don't produce identical frequencies) . After this mod is done the speakers are mirror imaged like later models (there is a designated right and left speaker). This mod does not affect bass output and to my ears actually improves the midrange (as well as imaging), as it reduces some of the frequencies that can make the stock original model "shouty" at higher volume. Your speakers can however sonically benefit from a re-build by replacing/upgrading the aged capacators and resistors. Westmassguy, (DHS Speaker Service) did a beautiful job on mine. There are several other mods that can be done (search the forum), such as gluing driver magnets, sealing cabinets, Dynamatting driver baskets, upgrading binding posts, upgrading internal wiring, renewing driver gaskets, etc. The original model is a very nice sounding loudspeaker once these mods are done.
    I hope this makes sense.
Answers
