Capacitor burn-in
Does the it mater on how many watts are are being pushed, volume? Should I vary it?
I am waiting on my sonicaps for my 7's and was just curious about this.
M7's 1982 Peerless tweeters
M5's X2 (1981 Peerless tweeters, 1988 with upgraded tweeters)
M4's X2 both with Peerless tweeters
M5Jr with SL1500 (in the garage, they sound great)
M4.6 series2 X2 with upgraded tweeters
SDA 2 with upgraded tweeters
Best Answer
    pitdogg2 Posts: 27,038
    edited December 2020 Answer ✓
    No just signal. Some leave the radio playing at low volume. There's no fast way I know of.
    All I can say is just play it like any other time. When mine broke in they was definitely times I had to walk away. I left mine play 24/7 for a good month, even after that there were "times" . A year later I sit in amazement every time I sit down.
    Good stuff.
Answers
  • invalid
    invalid Posts: 1,455
    Those sonicaps do need a few hundred hours to sound good, they sound good,then bad, then good, then bad, then great. That's when you know they are fully burnt in.
    F1nut Posts: 51,751
    wispolkboy wrote: »
    You have to shake them
    up and down and shake, shake, shake
    shake to the right, shake to the left
    turn to the right, turn to the left
    turn around and shake, shake, shake!
    VR3 Posts: 29,427
    When it looks like this
  • F1nut wrote: »
    wispolkboy wrote: »
    Since I don't have kids, nor do I listen to children's songs, I had to search this^^^^^. I lol
