Just picked up 2.3's...Basket case project! Need advice
    audioluvr Posts: 5,920
    Tony M wrote: »
    What speakers are those? They look fancy!
    nooshinjohn Posts: 25,931
    ^^^ no highs or lows, so they must be Bose.
  • But, it is effective as such.
    F1nut Posts: 51,793
    edited December 2020
    kickngas wrote: »
    No, it most definitely is not!!!
    "An effective vibration damper needs a precisely formulated visoelastic adhesive layer and a stout constraining layer"
    pitdogg2 Posts: 27,065
    That stuff will dry out crumble to the bottom of the enclosure.
    We've seen a thing or two ;)
    xschop Posts: 5,195
    Like dingleberries?
    This is the stuff I used. I mistakenly called it plumbers putty, but it is duct seal. Either way, not Dynamat.
