SDA SRS 1.2tl renovations
Big boys are all naked minus the tweeters. All parts are in hand for the upgrades, minus the crossovers that Dave at DHS is working his magic on.
-Threaded inserts
-Armacell to ensure speakers are sealed well
-Noico tape for baskets
-Silicone sealant for the cabinet
-Power grab for loose braces and speaker magnets
-Sound absorber for rear walls
-Stain and poly for walnut pieces. (considered recovering but the veneer is in very good shape)
I bought my first pair of 1.2tl's back in 1991 and kept them for about 12 years prior to selling. My brother had a pair of Klipsch K-horns and talked me in to those. Great speakers but I missed my Polks almost from day one. Well, about 7 years ago, I found these guys for an absolute steal and brought them home. I almost immediately changed out the tweeters to the 198's, upgraded the speaker/sda connecter plates, made a really nice SDA cable and pretty much haven't touched them since then. I finally have some time on my hands, so here we go. Super excited to see what these things will do when done. Thanks to all the Polksters out there that have shared their journey with upgrades. It's been a huge help in my quest to get everything I can out of these guys.
On a side note, the hardest part in taking these things apart was getting the side wood strips off without destroying the fabric. They were nailed and glued in place, so that made them alotta fun to separate.
SDA SRS 1.2tl's
Adcom GFA-585's
    F1nut Posts: 51,938
    Never use silicone anything inside a speaker.
    If your original gaskets are not damaged there's absolutely no reason to replace them. The gaskets are supposed to be paper thin.
    Noico tape is completely wrong. You want Dynamat Xtreme.
  • motorstereo
    motorstereo Posts: 2,359
    What.......... Khorns over 1.2tls? That was a big mistake and no doubt you missed the Polks from day one. Congrats to you on getting them back and good luck to you on your restoration-upgrades
  • I ASSume you mean Noico Sound Deadener. Which one are you using; I see they have 80 mill, 150 mill, and 315 mill. Glad you're back on track with Polks! You're brother isn't satan by any chance is he?? jk :D
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Boost1
    Boost1 Posts: 13
    I went with 80 mil. After comparing it and others to Dynamat, I decided to try this one. I have several friends in the area that have been using for quite some time and speak very highly of the results at a fraction of the cost.
    Satan, no >:) but while the K-horns sounded pretty good, it wasn't even close to the 1.2's. And yes; definitely glad to be back on track.
    SDA SRS 1.2tl's
    Adcom GFA-585's
    F1nut Posts: 51,938
    So, Noico dampening sheets not tape because this is the tape. https://noico.info/products/noico-tape-finishing-sealing-tape/
  • Boost1
    Boost1 Posts: 13
    edited December 2020
    Definitely not the tape. These are the sheets that come in varying thicknesses. Looking back at my original post, I see that I listed tape.
    SDA SRS 1.2tl's
    Adcom GFA-585's
  • JayCee
    JayCee Posts: 1,509
    I used Dynamat Xtreme in my 1.2tl's, 4 other SDA's and the inner cabin of my SUV. Last year, I used the Noico 80 mil on 3.1tl's.
    Boost1 wrote: »
    I agree with your friends and found it comparable in installation and affect. As Jesse (F1nut) states, do not use silicon because of off gasing and causticity to the drivers and XO's. Power Grab is the preferred product to seal the cabinets.
    Your upgrades will make what you loved about your first set even better this time around. Congrats and good luck moving forward.
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • Boost1
    Boost1 Posts: 13
    Thanks for the information, JayCee....much appreciated.
    SDA SRS 1.2tl's
    Adcom GFA-585's
  • Moose68Bash
    Moose68Bash Posts: 3,843
    Nice!
    Happy listening when the hearts start beating!
    F1nut Posts: 51,938
    The wood veneer is walnut not mahogany.
  • Boost1
    Boost1 Posts: 13
    Of course it is. I have absolutely no idea why I wrote that. Maybe too many bloody Mary's this am.
    SDA SRS 1.2tl's
    Adcom GFA-585's
  • boston1450
    boston1450 Posts: 7,758
    edited January 2021
    They look great. I'd steal them but dang they look to heavy :) Enjoy
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • Gardenstater
    Gardenstater Posts: 4,801
    Nice work! They look like furniture.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,337
    Agree x2
  • Boost1
    Boost1 Posts: 13
    Thank you. They were in pretty bad shape and initially I thought I would have to put new veneer on them but once I got them apart and began sanding, they cleaned up nicely. Fresh stain and then a few coats of poly and there you have it.
    SDA SRS 1.2tl's
    Adcom GFA-585's
