Are comp lcd monitors safe around non shielded speakers?
michael_w
Just a quick question that I couldn't find the answer to with a search... Are LCD computer monitors safe sitting in the middle of a pair of speakers that are not magnetically shielded? Thanks.
btw the speakers will be quite close to the monitor.
Post edited by michael_w on
I've been wondering the same thing, since I got my LCD
. As far as I know, magnetism wouldn't effect the picture, but there might be some memory chips in the monitor that could be screwed up by it? Ludicrous gibs! -
Thanks for the replies.
I did some more searching and here is what I found...
(copy and pasted)
Q:As no one on another forum seems to be able to answer this (or is it too obvious?).
Is there any danger to an LCD monitor of putting unshielded speakers near it?
I know this is a no-no with CRTs but assume LCDs are not worried about magnetic fields.
A:It should be a non-issue, as LCDs don't use magnetics to steer the non-existant electron beam.
The only danger might be if they produce a large alternating field, as this could induce currents in nearby wiring. Given that they're speakers, rather than motors, I doubt that'll happen. -
do you think that this would hold true if you have all 3 gaming systems as part of your ht set-up? can a non-magnet tower speaker...ah...say the tse300 at close proximity to your system wipe out a gaming hard drive? i have an onkyo 706 7.7 channel reciever, a cd player, all gaming consoles, an lcd that is also a monitor an 7 satillite speakers. just purchased 2 tsi300 floor standing speakers and the cs10 center and the floor standing speakers are not magnetically shielded. unfortunely, i didn't discover this til after i clicked the 'order' button. what do you think. am i in trouble with this kind of set-up? rebug
theres no way a speaker is going to wipe a hard drive. you should be fine if you have a lcd tv.
PaytonPolk monitor 10B's and 5 jr's
Adcom gfa 5500 and HK/240
Adcom gtp 400
Adcom gcp 600
MusicHall MMF 2.1 TT
