Saw Kerfs inside back panel?
Why did Polk cut the vertical and horizontal kerfs into the back panel of the 2.3 speaker? This would seem contrary to wanting a rigid cabinet.ax98f3mq52ud.jpg
  • Gardenstater
    Gardenstater Posts: 4,783
    edited December 2020
    I have read here on the forum that it is to break up standing waves. I suspect that it is a destructive interference diffraction effect that is effective on a certain wavelength based upon the groove spacing and distances from the side panels. Looks like they did it with a CNC router.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    pitdogg2 Posts: 27,069
    Correct to break up standing waves.
  • I think in a sealed enclosure design (no port or passive radiator) you can fill the entire enclosure with polyfill to help eliminate standing waves, but I'm thinking that they want to keep the area behind the passives free of anything that would interfere with the speed of sound transmission from the MW's to the passive. Perhaps the grooves are the best solution in this case.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 51,793
    Freeman built your speakers, you should be honored.
    The grooves are present top to bottom, but are shallow, so no compromise to the rigidity.
  • I tip my hat to Freeman, he did a fine job! I feel honored :D . It would be cool if some of those Polk assemblers were present on this forum.
  • I wonder if Freeman cleaned up the glue squeeze out. Usually there is lots of it visible.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • I will follow behind him with some caulk in the seams just to be sure it it all sealed up.
    F1nut Posts: 51,793
    kickngas wrote: »
    Do not use anything with silicone in it.
  • F1nut wrote: »
    kickngas wrote: »
    Great advice...Power Grab it is!
    F1nut Posts: 51,793
    There ya go.
  • Jstas
    Jstas Posts: 14,985
    You can use silicone you just have to wait a long time for it to fully cure. Once cured it's pretty inert. But the curing process off-gases chemicals that will degrade speaker components pretty badly.
    When I was building sub boxes for competitions I'd seal the inside with silicone and let it sit with a fan blowing in it for like a week before I put any speakers in. I never had a problem. But I also never rushed it either.
    You gotta really watch the construction adhesives too because they use similar chemicals to keep it pliable so it's does set in seconds. So make sure you read the instructions completely.
    Expert Moron Extraordinaire
