Keep or trade SDA 1C's?
Hi all,
Been reading through some of the content here and am grateful for it. I just recently picked up a pair of SDA 1C's while on a road trip for $200. I was originally thinking I'd use my Pioneer SX-1250 to drive these speakers. I was pretty excited to upgrade from my Monitor 5's but after speaking with DHS Speaker Service (discussing upgrade options) I've learned that these speakers need a preamp or power amp to drive them correctly. I'm sort of at a loss of what to do from here so thought I'd solicit some feedback from the friendly folks here.
I love my 1250 and have invested prob $1,500 over the past 2/3 years in refurbishing it including the purchase price. I want to stick with it. DHS suggested either switching to Monitor 7's or I could just use the 1C's without the interconnect but that without the interconnect, they're just regular speakers. So I'm wondering, will the 1C's still be better than the 7's without the interconnect? Or should I just try to sell the 1C's for what I can and try to find some 7's?
My goal is to put together the highest quality system I can using the 1250 I already have and that has been fully refurbished. Are there other speaker recommendations or options I should consider? I'm open to any thoughts. I would like to keep my speaker budget under or around $1,000. I do like the way Polk speakers sound. I love the 5's but just feel like they're a bit small for the 1250.
I listen to Classic Rock, Country, House, Electronic, Big Band, Jazz. Room is about 25x17. Willing to put in some effort on upgrading crossovers, etc.
Would appreciate and wisdom you folks could share.
Here are the specs from SDA Manual. They are stated to be 6 Ohm nom. Impedance and your receiver is rated for 200WPC into 4 Ohms. Rec. amplifier power is 50W - 500WPC. Efficiency 90dB. Your receiver has a damping factor rating of 30.
This requires a common ground amplifier or receiver, but since virtually all receivers are common ground you should be OK. From the manual https://polksda.com/pdfs/SDA1C.pdf
George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
dunno why the 1250 wouldn't work.
give it a try .
way back in 1988 or so when I got my 1C's I used a Yamaha R9 receiver (125w 8 ohms) with them for about a year until I got a B&K ex-442 amp (200w 8ohms) - worked fine !
bkPS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO -
It appears your receiver may be dual mono and may not share a common ground.Pioneer developed the now legendary power section of the SX-1250 with completely independent power supplies, including separate power supply windings, rectifiers and smoothing capacitors for each channel
You can test this by checking the resistance between the negative outputs of the left and right channels. Do this with it unplugged.
President of Club Polk -
Definitely good to check. Schematic shows a common ground.
https://www.hifiengine.com/manual_library/pioneer/sx-1250.shtml
There is a review of your speakers ($200 wow!) on p. 41. You will have to go over them and people here will help you with that (Post some pics!), but you probably have struck gold:
https://worldradiohistory.com/Archive-All-Audio/Archive-HiFI-Stereo/80s/HiFi-Stereo-Review-1987-11.pdf
Post edited by Gardenstater onGeorge / NJ
iFi nano iDSD DAC
iPurifier3
I love my 1C's! If your vintage receiver has been refreshed properly, it should work fine. You can always upgrade to better components later in life.Gustard X26 Pro DAC
Thank you all for the feedback. I also just read the below on another post from a while back.
"The twin/blade speakers would short out the non-common ground amplifier. The pin/blade speakers don't short the amplifier, there just isn't anything coming from the SDA components." - I have the pin/blade interconnect cable.
Also pulling from another post: "You can touch the a probe from a VOM to each negative speaker terminal with the meter set to the lowest range, usually 200 ohms. If it's common ground the reading will be 0 or close to, like 0.5 ohms."
I'll check this this afternoon. Unfortunately, 1C's are not very wife friendly speakers. I may need to find a new home for them. I'm in Charleston, SC if anyone is interested let me know. -
So I took the reading and tried two different VOM settings for Ohms. The first was at 200kOmega and it read 0. The second with the VOM set on 200Omega and it read .6 and .8. So unless someone says otherwise, I'd say the receiver is common ground and it is safe to use the interconnect cable. I shouldn't have any trouble with my receiver or cause any damage and the SDA effect should function properly?
Yes. And the schematic I posted above for your receiver clearly shows that it is a common ground. If you touch the probes of your DVOM together when it is on the lowest setting of 200, what do you get?George / NJ
iFi nano iDSD DAC
iPurifier3
Thanks Gardenstater. I get .5 or .3 depending on which setting I have it on.
Should be the same reading as you got when touching the probes to the Neg binding posts on amp, but, as they say, close enough for govt work!
George / NJ
iFi nano iDSD DAC
iPurifier3
Haha. Thanks again all.
Now I just need to figure out how to get the wife on board with these monsters. She certainly does not like the look and size of them. -
Maybe a doilie and a vase with a rose on the top of each one?
George / NJ
iFi nano iDSD DAC
iPurifier3
Stuff on top of the speakers? Never! 😈
Say what!?!Political Correctness'.........defined
dromunds......it was a joke.
MLampen.....perhaps you can sell them to PolkFanVA so that he can use them as his garage speakers and move the RTA12B's into his office.
George / NJ
iFi nano iDSD DAC
iPurifier3
Gardenstater wrote: »dromunds......it was a joke.
I realize it was a joke. That’s why the emoji. Although I must say every time I see things on top of speakers I involuntarily cringe. -
Slap her on the a$$ and tell her to get over it...Gustard X26 Pro DAC
