Thalassemia??
Toolfan66
Anyone heard of this before? Doctor thinks this is what I have as my endoscopy and colonoscopy came back clean, weird thing is I have been getting a physical every year since I turned 40, and this has only been brought up the last three years, I just recently changed doctors, he had me do lab work, and called me about it today. So I’m back to revisiting it again.
https://www.mayoclinic.org/diseases-conditions/thalassemia/symptoms-causes/syc-20354995
I never heard of that. There must be a million medical conditions, and I'm surprised doctors can keep up with them. Good luck. Hope it is the mild form.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
New one on me Larry. Maybe it's just the fact you're getting old
President of Club Polk -
Good luck.MIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?”
Thalassemia - problem with the o2 carrying protein WITHIN red blood cells.
This causes either less o2 carrying capacity within each cell and may cause issues with red cell lifespan which would then lead to anemia (low red cells).
It is inherited.
There are 2 parts, alpha and beta, an aspect of hemoglobin chains (o2 carrying protein). Abnormal chains can cause kinks - which can cause problems with production of red cells (erythropoeisis) and early death (hemolysis, anemia).
Typically it does not cause symptoms if trait (alpha trait, beta trait).
However, alpha major, beta minor, beta major cause issues. Typically the more major, the earlier it affects (from birth) which could cause poor growth, abnormal skeletal survey, and frequent transfusions.
As far as I know, there is no treatment as this is a genetic disorder.
But I surmise that as you get older and there are other reasons for anemia, then something that typically would not cause symptoms such as a minor thalassemia variant would begin to cause issues.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
It is inherited.
PFFFT! what do you know!!!
It is inherited.
I know... nothing!!Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
If you've cut back on red meat, then your metalloprotein hemoglobin may be the culprit. A good multivitamin with Ester C along with iron is good insurance.Don't take experimental gene therapies from known eugenicists.
@Joey_V
Glad to see you're still posting and all this covid stuff hasn't burnt you out yet and that you and your family are staying healthy and well. -
@Joey_V
Only a few more months till the vaccines... phew.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
"good insurance."
Wow and here I thought Larry found another excellent band that I needed to buy the CD.
Hang in there pal, at our age it seems more gremlins pop up in the strangest places. -
It is inherited.
Joey, can this just creep up on you as one gets older? I have been getting a physical every year since I turned 40 and it only came out the last couple years..
It’s something I will discuss with my doctor once he gets my files from my other doctor and he is doing another test, so it will be a couple days I’m sure..
It is inherited.
It’s not readily apparent. The tests are specialized. You would’ve already known if you had the major subtype as you would’ve already had transfusions by now.
The minor ones... it might be just subclinical.
I wouldn’t worry about the minor subtypes unless you have symptoms.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
Good luck man
Lemme know how you fare with the repeat visit
If you have questions or need me to clarify, just PM me with some pics of the lab tests and I can look through them.
I have friends in all specialties and I can get a consult with a dozen docs in a matter of minutes.
It’s the best part about being in the frontline. You may be a master of none, but you have a friend in all.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
I’m thankful that there are people here, like Joey, who are willing to spend time helping us out when it’s needed.
^ Agreed. Specially knowing how busy he must be currently."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Good luck man
Thank You Joey,
I got a call from my doctor after he did some other blood work, he has ruled out Thalassemia, he wants me to do another Colonoscopy, and Endoscopy, says my Iron levels are low, makes no sense to me since I came back clean on the last ones, so how else could one be losing blood, or have low iron levels, what could have been missed from the first ones, and it's not cheap to get done... Frustrated!!!
