Wood vs. metal chassis for vacuum tube equipment
I wonder if a wood chassis could have a positive impact on the sound of a preamp or power amp vs. a metal chassis. I know it's just a case for the electronics but it might resonate different than metal. Any opinions or experience?
    mhardy6647 Posts: 35,200
    edited November 2020
    From an engineering standpoint, metal is historically/generally preferred for shielding,
    FWIW.
    You may have noticed that you see very, very few nonmetallic chassis in hifi componentry.
    B)
  • Emlyn
    Emlyn Posts: 4,812
    A wooden chassis may have problems getting consumer electronics safety clearance. Wood was of course long used for exterior casework though, but mainly for style.
    People have good results by using high quality racks made of thick wood materials for resonance control.
    nooshinjohn Posts: 25,984
    Granite has its virtues as well.
    pitdogg2 Posts: 27,234
    I would have never believed it until I heard it, Some rocks ring like church bells. I went to a mineral museum and they were showing how to tell the differences in rocks. The guy hit several pieces of granite, marble and other I cannot remember now. I was floored at the sounds they made and just rang and rang.
    ZLTFUL wrote: »
    So does wood. Do a YouTube search for tongue drums.
    Yep
    Granite is notoriously ringy. Things like soapstone are much better for antiresonance applications (e.g., plinths).
  • invalid
    invalid Posts: 1,519
    I don't seem to have any problem with hum or rfi, and my pre is made of wood, plus it uses ac heaters. Ac heaters are supposed to be noisier than DC heaters.
    invalid wrote: »
    Then why did you ask? Sounds like you have the data already! :)
    Granite works well on my tube amps...
  • BlueFox
    BlueFox Posts: 15,250
    invalid wrote: »
    Do you have any pictures? I don’t think I have ever seen a wood chassis for a preamp.
  • delkal
    delkal Posts: 764
    BlueFox wrote: »
    invalid wrote: »
    https://bottlehead.com/product/beepre-300b-preamplifier-kit/
  • BlueFox
    delkal wrote: »
    Is that what he has? It looks like a metal preamp chassis in a wood frame.
  • invalid
    [/quote]
  • BlueFox
    Cool. Thanks.
