Which monitor 7
I got these as free and appear a bit beat up. Have not tried yet. Only ID I have is on back is tag that says Monitor Series and stamped into it is " 7 16831 "
I would like to know what I have before delving into them. There are no fuses on back. There might be three probe holes next to the speaker terminals.
I would like to make sure I don't blow my Yamaha currently pushing a pair of Pioneer CS-C9900 on the front pair.
  • Gardenstater
    Gardenstater Posts: 4,804
    edited November 2020
    Mine are marked 7 19XXX with a small tag on the XO cup and are 7B's with the one tweeter protector fuses. I know that very early 7's even had 2 fuses, one tweeter and one system. The 3 holes are where the fuse block would've been. It is possible that someone removed the fuse block. Take out the XO and look. Just put up a picture of front and back, with and w/o grille and you'll get ID from us probably immediately. I don't know for sure if they started over with the serial #'s when they went to a new model of 7, but I believe they did. There was the 7, 7A, 7B, 7C, and Series II afaik. After the 7B they had no fuse and used a polyswitch on the XO pcb. I'd guess that you have the Series II.
    Also, tell us what model of Yamaha you have.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • My 7Bs have an approximate 1x3 inspection label above the XO cup, labeled as 7B, one fuse for tweeter and SNs 15193/15232.
