More preamp decisions
I keep coming around to debating another preamp. My RLD-1 is naturally an aged component but still sounds good, this is to pair with a recent Ultra Platinum DNA-1.
I want to hold out and try the BHK preamp, but for now, I'm trying to stay under the $2K mark and my search keeps bringing me to the MF M6S.
I would like the HT bypass and a remote. I also looked at some used JC-2's but they surely hold their value.
The MF gets a lot of praise here so curious to who has one and what they have compared it to.
I wanted to stick with SS but some pre's have a single or a pair of buffers, that might be fine. The DNA-1 wasn't too happy with a high-gain tube pre, sounds good, but the tube rush was too much.
This will be used with the 2.3 TL's.
All input and criticism appreciated.
  • dpowell
    dpowell Posts: 3,081
    After hearing a Pass Labs X1 pre that @nooshinjohn brought to a polkie gathering at my place, I knew I wouldnt be satisfied with my 2.3TLs until I bought one for myself. The sound is phenomenal. I have it paired with a Sunfire Signature Cinema Grande 400x5. The X1 has the HT and remote capabilities you want. You should be able to find one close to your budget.
  • gmcman
    gmcman Posts: 1,839
    Thanks, I did look into the Pass, and was aiming towards the XP-10 only because it was a bit newer, but not a deal-breaker. Hard to find the XP-10 under $2K though.
    I don't know enough about the Pass preamps to make an informed decision, but I will also look into the X-1.
    Clipdat Posts: 13,087
    Personally I would look into the Benchmark LA4, but it's above $2k.
  • Jazzhead
    Jazzhead Posts: 526
    I'm very happy with my Ayre K-5xemp. It's very neutral, detailed and dead quiet. I started looking into this model when I read it was Stereophile's least expensive "Class A" rated preamp for many years. They can be found used for $2000 if you watch diligently. If you go this route be sure you get the "mp" version (the upgraded version):
    https://www.stereophile.com/content/ayre-k-5xesupmpsup-line-preamplifier
    pitdogg2 Posts: 26,933
    I've always been a fan of the Ayre stuff. Incredible sound.
  • pearsall001
    pearsall001 Posts: 5,236
    The Rogue Audio RP-1 pre is stellar & well under your 2k budget. Well reviewed & sounds fantastic!
  • engie490
    engie490 Posts: 438
    I would look at the Wyred 4 Sound STP-SE. It's passive until it hits unity gain. The DNA-1 has more gain than most amps (30db) and a high input impedance (100K). So, it's really a good choice for using a passive preamp.
    Remember, McCormack/Mod Squad had passive preamps before they started making any with gain.
    Hales System Two Signatures / Bryston 7B STs / McCormack RLD-1 / Innersound Phono / Bluesound Node 130 /Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
