Mw8002 driver
buzzard5357
Are there any mw8002 drivers available or what can I use as a replacement. Only one is needed or I will dispose of the set.
Midwest sells a replacement.Political Correctness'.........defined
President of Club Polk -
That's https://www.midwestspeakerrepair.com/ right?
RightPolitical Correctness'.........defined
Thanks!
Thanks for that but unfortunately none available
buzzard5357 wrote: »Thanks for that but unfortunately none available
They have them on their site and also listed on eBay. Would you like someone to open the box for you after it arrives too?
https://www.midwestspeakerrepair.com/shop/home-audio/woofers/mw-audio-1/mw-audio-mw-8000-8-inch-polk-audio-copy-woofer/
https://www.ebay.com/c/1842354159Political Correctness'.........defined
Yes, that would be nice. Also if you would install it that would be great.
I will pay for it !
