Monitor 7's on old tubes - anyone else?
I came into this near mint 1962 HK TA500x, a pair of Jensen H-222’s and a very nice (but dusty) Garrard Type A II turntable last weekend (Pickering model 380 red cart 😁). A little elbow grease and the HK is sounding pretty sweet on the Jensen's. Still has one channel that’s a little lower in output, but the tubes all appear to be original, so they may be a little long in the tooth...
So tonight, I figured it was time to move to the 8ohm taps and try some monitor 7’s. Oh my... I’ve been sitting here with Norah Jones in my garage for an hour or more. What a fantastic pairing. This ol tuner might just stick around. Anyone else have experience with a combo like this or this tuner?
Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), Full mod SDA CRS 4.1TL (198’s), SDA SRS 2.3TL (198’s), R100's, R200’s, R300 🤩
Pairs that have passed through: Monitor 4b (Peerless), Monitor 5a (Peerless), Monitor 5B (Peerless), Monitor 5b (SL1000), Monitor 5b (SL2000) (4x pair), Monitor 7b (Peerless), Modified Monitor 7c’s (194’s), Monitor 10a (Peerless), Monitor 10b (5x pair), RTA8, RTA8TL, RTA 11T, RTA12c (194's), SDA1(mod to “a” & SL1000 Wuhan mod), SDA CRS, SDA 2 (2x pair), SDA 2a, SDA 2b, SDA 1b, SDA 1c, SDA SRS 2 (2x pair), SDA SRS 3.1TL (198’s) (2x pair)...and more to come, it’s a sickness.
  • verb
    verb Posts: 10,176
    Nope. But love the setup! Very cool!
  • VSAT88
    VSAT88 Posts: 1,373
    Well folks here may call loco on this but oh well. I have enjoyed many a time my Fisher 500C receiver with my SDA 2b speakers as well as other Polk audio M5's M7's and M'11's . Used a rebuilt Dynaco ST 70 with some of them as well. Liked that too. I no longer have the 7's 5's 11's or the Dynaco but the Fisher and the SDA 2b's aint going no where.
  • teekay0007
    teekay0007 Posts: 2,288
    JayMX wrote: »
    Well, send her home! Tell her I'm getting hungry...and it's almost bedtime. ;)
    audioluvr Posts: 6,022
    JayMX wrote: »
    Nice!
    xschop Posts: 5,677
    Double like. Still have my eye open for an old HH Scott tube setup. Will you rebuild the unit?
  • BlueBirdMusic
    All BEAUTIFUL!!
    Original tags on the Jensens?
    Harry / Marietta GA
  • Gardenstater
    Gardenstater Posts: 4,858
    edited October 2020
    Too cool. At first I thought it was two tuners (receivers actually), one stacked on top of the other. 30W per channel. There may be a schematic for download here:
    https://www.radiomuseum.org/r/harman_ta_5000xta5000.html
    The only experience I've had with a receiver was my old Technics SA500 and I'm sure it doesn't hold a candle, being solid state and no tubes.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    mhardy6647 Posts: 35,420
    edited October 2020
    That is nice stuff :)
    Although those Garrard changers make me nervous. I think I'd rather adjust a bank of Weber carbs on a vintage British sports car than work on one of those! ;)
    I - typically - want to offer a completely solipsistic response to the thread title. :blush:
    Long, long, long, ago -- when I spent a bolus of real money (to me, at any rate) on eBAY and bought, and rehabbed, an EICO HF81 -- I tried the amplifier on pretty much every pair of loudspeakers in the house. The HF81 is a great sounding push-pull EL84 stereo integrated that makes pretty much any loudspeakers sound great -- but, for whatever reason, it didn't mate well at all with my Monitor Series model 7As. The sound was thin and kind of shrill -- and the latter characteristic, in particular, is not a hallmark of the "Monitor Series" of the late 1970s.
    I never repeated the experiment, nor do I have any insight as to why that would have been the case. It might have been worth trying different output taps on the OPTs on the EICO, come to think of it (and more than 20 years later!). :p
    EDIT: The separate AM & FM tuners were configured to permit reception of the early (pre- FTC licensure of "MPX" stereo FM) "AM-FM simulcast stereo" broadcasts. We don't have any of those any more ;) but the AM tuner section of this receiver should be of notably higher audio (and maybe also radio) quality than the average "modern" receiver AM section.
    Post edited by mhardy6647 on
    edited October 2020
    Oh, and... :)
    The only "problem" with some of those lower-powered h/k components was that they used weird output tubes. I have an h/k receiver (very low end... a kit model, in fact) that used 7408s (which are actually "just" 6V6 variants, fortunately). I think (???) that the TA500(x) might use 7355s? They're not easy to find , and the one "modern" replacement (last I knew), the Russian "7591XYZ" is probably as hard ($$) to find as are NOS 7355s. Just a thought.
    The output may be one of the preamp or driver tubes (are they 12AX7s?) -- or bad coupling capacitors. I would definitely recommend replacing all of the coupling caps if they haven't been done in the last 20 years or so (i.e., if they're original).
    Also, be wary of the P/S multi-section electrolytic cans caps. :( They're way past their EOL if they're original. One can source more or less exact drop-in replacements, but they're kind of pricey. Some folks re-stuff the orignal cans with modern electrolytics (which are usually small enough to permit that) or just add modern ones underneath -- or go with modern replacements like F&T in place of the cans.
    My rule of thumb (which comes with NO GUARANTEES!!!) -- if you run the amp for a while (say 1/2 hour) and the cans are cool/cold to the touch (and, of course, there's no P/S hum on the audio output)... they're probably fine. If they're warm or hot --they're bad. :|
    Sometimes a nearby component may heat them by radiation, but it's usually pretty to tell.
    My apologies to @JayMX if all of this is old news to you (and/or if the h/k's been rehabbed sometime in this century ;) ).
    EDIT:
    1) The titular h/k of this thread does have some nice, beefy looking output iron in it! Many of the low powered h/ks tended to have kind of wimpy (dare I say anemic? B) ) output iron.
    2) Gary Kaufman's synopsis of the 7355 :)
    The 7355 is essentially a 6L6 electrically, with a 7591 pinout in a 6V6 bottle :)
    Even if you re-pin the socket as a 6L6 you'll still have the problem of bottle size. Admittedly 5881's are the correct size - but they aren't any cheaper than 7355's.
    source: https://antiqueradios.com/forums/viewtopic.php?f=15&t=184303
    PS That forum thread is well worth a look, as it has some tidbits of info about the TA500x, a receiver with which I personally have zero experience.
    PPS Threads like this one give me the itch to start playing with some of the electrically unrestored dowagers lurkin' around here... :)
    pitdogg2 Posts: 27,631
    I see the tubes Mark mentioned out on ebay some are new production Soviet Tung -Sol
    Oh, that's interesting -- I did try to disclaim that I wasn't up to date on the 7355 supply... but I didn't try very hard. :p
  • JayMX
    JayMX Posts: 461
    @mhardy6647 - always a pleasure to read your discourses. 👍🏻 As you know, I’m a relative tube-noob, so I’m just fooling around at this point. Not sure if I will keep and rework or build a wood box for it and resell. As it stands I believe it to be 100% original, never serviced afaik. I was just so enamored last night that I thought I’d share. Good times. Got some studying to do it seems. Thanks all!
    As you know tomorrow may be a different story. I've lost count on how many times there's a plethora of tubes one week and for the next 3-8 months none to be found.... anywhere.
  • dromunds
    dromunds Posts: 10,161
    Good output iron. That's key. I have a pair of rebuilt 1950s Heathkit W5-M tube mono blocks that have Peerless output iron and they make my Monitor 7's SING!
  • lavane
    lavane Posts: 8
    I recently picked up a pair of monitor 10's and they play nicely with my VTA ST-70 35wpc PP tube amp. I have a Dynaco clone ST-35 17.5wpc tube amp on a switch with the ST-70, and the smaller ST-35 does a decent job as well all though not as loud.
    I was a bit worried the Polk's wouldn't mesh well with tubes, but they do. Plus with tube amps i have 4,8 and 16 ohm taps i can use to help dial them in. Output transformers are much more forgiving when connecting, say a 4 ohm speaker to an 8 ohm tap. One tube amp I have sounds best with 8 ohm speakers connected to the 4 ohm taps.
  • pelhamplace
    I’m looking at local garage sales to find some monitor 7s that I can pair with a Fisher 500c or Scott 299c.
  • lavane
    lavane Posts: 8
    I'm currently using a pair of monitor 10's with a VTA Dynaco ST-35 UL PP amp and the 10's sound wonderful with it. This amp is a 35wpc amplifier and can still drive them stupid loud.
    I would think the 7's would work just as well with tubes. I had the same question before I bought the 10's. Glad I bought them. They also sounded good with my little 17.5wpc Dynaco ST-35 PP amp. It just couldn't push them as hard.
