New supercar speed record
F1nut
whoa.
uff da. -
And Koenigsegg says that their Jesko Absolut will be faster.
I think the engines and chassis can manage just fine. Just thinking of the rubber at those speeds is crazy.Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
I would think they would get more HP out of 91 octane than ethanolGustard X26 Pro DAC
Ethanol has a much higher octane.
Whether that is the difference idk?
Either way that is purdy effin fast! -
.E85 can handle higher conpression/boost without detonating which allows for higher turbo boost.
Makes more zoom zoom.Sal Palooza -
How much more could it go? He wasn’t struggling to game MPH at the end which leads to believe he could have hit 340+Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!!
Was the A/C on?Political Correctness'.........defined
President of Club Polk -
Neat camera play to get a sense of the cockpit setup.I disabled signatures.
GeezMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
Your next car Joey?Political Correctness'.........defined
Too run-of-the-mill for Joey
I think I counted 5 gear shifts.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Gardenstater wrote: »I think I counted 5 gear shifts.
Around 140mph coming out of 3rd2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
wait -- it doesn't have a CVT automatic?
OK, now I am interested.
George / NJ
iFi nano iDSD DAC
iPurifier3
In the end, it's all about the tires2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Yeah? Put some Cragars on an F-16!
Wow! I wonder if he just ran out of road. Very smooth too!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
They smashed that record.
We have a doctor motorhead group - I saw this article on that place before here.
It is amazing how fast these hypercars are. Not like we would ever push it to their limits, being amateurs.
I believe the current limits would definitely be the tires. Something spinning > 300mph is insane.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
I cipher that those tires are rotating in the neighborhood of 4500 RPM.
Dragsters do that but only for a 1/4 mile and their tires "grow" like crazy at launch.
That car's tires do it over a much greater distance and are under massive stress.
Simply amazing.Sal Palooza -
Hitting a Junebug at those speeds would probably total the car.
I would love to *own/drive it up here where I can put seasonals on it for snow driving fun!
*I can’t even afford the wiper fluid. :'(Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Sad they had to cheap out on the BOSE sound system.Don't take experimental gene therapies from known eugenicists.
That ain’t fast... hell, I used to routinely make .98 Mach on the way home for the crapper after a bad trip to Taco Bell.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »That ain’t fast... hell, I used to routinely make .98 Mach on the way home for the crapper after a bad trip to Taco Bell.
...and that's at or near sea level, too... where the speed of sound is considerably faster than it is up at 30,000 feet where them big ol' jet airliners fly.
mhardy6647 wrote: »nooshinjohn wrote: »That ain’t fast... hell, I used to routinely make .98 Mach on the way home for the crapper after a bad trip to Taco Bell.
Only you could put an educational spin on Noosh's post.
Well done!Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!!
