Audioquest Bedrock speaker cable 6.5ft pair w spades and bananas
geppy1
geppy1 Posts: 3,076
edited October 2020 in For Sale (FS) Classifieds
Selling Audioquest Bedrock speaker cable 6.5ft pair w spades and bananas as I am no longer using them. Classic older AQ. All new ends with amp end having bananas and speaker end has spades They can switched if you cut the tape/heat wrap and undo the 2 tiny screws or bare wire them for less interaction. They can also be internal biwired . The older AQ stuff is good Asking $80 Thanks
  • CH46E
    CH46E Posts: 3,595
  • vmaxer
    vmaxer Posts: 5,121
    I still use some of these.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • I have some Slate ones. Very good.
    Harry / Marietta GA
