Any Web Developers Out There
I am pondering a website for my business, Virtual Classroom Facilitator, which right now is only on Facebook. I am a website novice at best using DW to design. Q - is it a good idea to design it myself or do I run the risk of having someone fix and bunch of code to get it to display properly on various screen sizes. Also, if anyone is interested in some work, drop me a PM. The site will be informational mostly....simple and organized yet not boring if that makes sense.
  • CGTIII
    CGTIII Posts: 1,259
    Been many moons since I used one, but there are sites that will model a site at different resolutions. One way around the issue is to design for a fixed common resolution, usually 1024 or 1360 pixels wide. Also, there are numerous attractive yet inexpensive templates available that save a lot of work.
    Boston - CR7, CR6s, CR4s.
    ​Thompson Adventures, Inc.
