New speakers!
Just ordered a pair of R15's from Frys for $50 to use in my cubicle. I'm going to try powering them with a t-amp because most of the time I can't play them loud anyway. In the evenings I could crank them up though. Any cheap suggestions for power?
madmax
madmax
Vinyl, the final frontier...
Post edited by madmax on
I meant to post a pic. I'll try again.Vinyl, the final frontier...
how about using one the dozen amps you have laying around the house - FREEDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Wow!
Those speakers look absolutely gorgeous with the cherry finish.
Nice catch, you'll make em' all jealous. -
maybe look at a nice vintage Pioneer integrated amp. to run those babies. vintage Pioneer is pretty sweet sounding.PolkFest 2012, who's going>?
At one point I had a pair of SDA-CRS and a tube amp here. Although nothing has ever walked away it made me nervous so I took them home.
Vintage would be cool but I need something somewhat small. My sources are a PC and XM radio so I need to switch between the two. I can change the 1/8 inch jack if necessary to switch sources. I would like something nice sounding and small.
I'm quick on the trigger today! I ordered a Teac A-L700P T-amp. Zero seemed to like it a lot...
http://www.needledoctor.com/s.nl/sc.2/category.271/it.A/id.2206/.f
i liek them better then the rtis and the montiro line :eek:
Cherry looks good for those. The black ones at the store look like crap.
Max -- Keep us posted. I'd like to know how the Teac compares to the Sonic Impact. Can you hook up a source directly to the Teac?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
That is definetly a sharp looking speaker in the Cherry finish.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Heads up- those rR15s re back at $50/pair. R50s are $80each. Easy on the eyes and good for those on budgets.Fulmer
TV: Hitachi 51F500
Receiver: Yamaha HTR-5240
Mains: R50
Center: CS245i
Surrounds: RT25i
Sub: Atlantic Technology T70 -
One more question -- will the Teac accept banana plugs?
I asking because I was going to purchase a Sonic Impact and buy the custom aluminum chassis and install 5-way binding posts, etc. I'd rather purchase a T-amp that doesn't require any mods.
Thanks.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I think if you are considering the high eff speakers the SI is probably the way to go. (from what I've read). The SI seems to be making a hit with the high eff crowd wich is not an easy thing to do.
For those interested in the TEAC Tripath power amp, here are some threads over from audiocircle.com
Start with this one first (19 pages)....
http://www.audiocircle.com/circles/viewtopic.php?t=11728
Then stock TEAC vs. modded TEAC
http://www.audiocircle.com/circles/viewtopic.php?p=141414#141414
I have been meaning to get one of these TEAC amps, but my PS Audio speaker cable purchased sidetracked the project. Yes, the TEAC has binding posts in the back. No detachable power cord though.
Man, those R15s looks damn good in cherry. -
I didn't realise that they were $50/ PAIR!!!
Just picked up a pair, myself (I hope... they said "call for availability"). I'll probably drive them with my Pioneer SX-450, if it's enough.
Can't wait to get 'em.Ludicrous gibs! -
http://www.needledoctor.com/s.nl/sc.2/category.271/it.A/id.2282/.f
does anyone know if this integrated is a common ground for use with a CRS+?
Max thanks for the link... you will probably responsible for my fisrt **** chewing from mama this year;)
HBomb***WAREMTAE*** -
Great links DT!
Hbomb, I am very happy to get you in hot water, anytime!
From what I understand the pcb inside the unit is set up to allow for 4 channels. One is left unpopulated. I'm guessing here but I think they probably use two channels from one IC and one channel from another. The dual outputs from the one chip (if that is the case) would not be common ground. BUT, if I'm right about the two chips, the second one could be tied common with one of the first two. All guesses though. I'll investigate it once I receive the amp. Obviously the first thing I will do when I receive it is rip it apart.
madmax
Here is a link for the R15's in case anyone else wanted to order a pair. For me they were $50 plus $10 shipping.
http://shop4.outpost.com/product/4205294Vinyl, the final frontier...
Just an FYI... I ordered some R15s yesterday to use as surrounds and they show mine as backordered. So I don't have my hopes up...Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15
just called since i ordered 2 pair this morning and they are back ordered till the 25th of Feb but are already backorderd some 300 pair's..Looks like if i get lucky it will be sometime in march from what he tells me. This sucksLife without music would♭
I'll second that! Great find, if they sound as good as they look you should be very happy.
If only I could have a pair of those at my desktop/workplace.....
It's better to wait than to be told they are unavailable.
I just hope we get them.
Damn.... and they already have my money
I can't wait until MARCH. By then I'll have forgotten that I paid for them. The black ones are shown as being in stock and available, though. Do they really look that much worse?Ludicrous gibs! -
Here is a pic of a cool looking tri-path amp.
http://images.google.com/imgres?imgurl=http://www.geocities.co.jp/MusicHall/5687/MyAmp/TriPath.gif&imgrefurl=http://www.geocities.co.jp/MusicHall/5687/MyAmp/TriPath.html&h=600&w=800&sz=11&tbnid=bys7ZqmByW8J:&tbnh=106&tbnw=141&start=4&prev=/images%3Fq%3Dtripath%2Bamp%26hl%3Den%26lr%3D
madmax,
Have you seen the TEAC Tripath amp when painted black? Very cool. -
Did you see the price for the black ones? $129. That is why the cherry ones are such a deal. They look better and cost a lot less.
No on seeing the black ones but that is a great idea! Actually I may try a very radical color. Maybe red or yellow. Maybe yellow and black. Maybe purple.
Yeah, I did just notice that the price is much higher. I wonder... if, on the off chance that the Cherry becomes no longer available, they would give us black instead.
I'd rather be on the waiting list than not get them at all, I guess.Ludicrous gibs! -
madmax,
Go to the below link and you will see the TEAC (and its back panel) after it was painted back....
http://www.audiocircle.com/circles/modules.php?set_albumName=albuo42&op=modload&name=gallery&file=index&include=view_album.php -
Okay, so these speakers are rated 20-100 watts each. The receiver I'd like to drive them with is a vintage Pioneer SX-450, which is only rated at 15wpc. However, I've never had problems with it driving speakers larger than these. It can't handle my Monitor 10's, but it runs my 5jr's pretty easily. Any thoughts? Should I dig up one of my other old receivers that might be rated higher?
These are going to be used in an office room with a PC as the source. Plus of having your brother as your boss... he likes loud music, too
Ludicrous gibs! -
Often a small speaker requires more power than a larger one due to efficency.
Looks like I have at least 30 days to wait... I'll probably forget I ordered them.
DT, yes, the black is VERY nice. Did you get the texture that way with special paint or did it just happen? Nice system too, except for that EQ futzing everything up.
I especially like the two amps sitting together and the granite on the other components. Very serious DIY!
madmax,
The system in the photos isn't mine. The owner of the system sold his $1,200 integrated amp (which cost more than my entire system) and replaced it with 2 TEAC amps. I e-mailed him regarding the black paint though and here's his response....Well, I used some "bed liner" spray paint that I found in a local store - I thought that since it stays a little flexible, that it might help with damping the chassis from vibration, as well as meet my need for dark components.
It is a textured paint, so if that appeals to you, I am sure that in the US Pep Boys or somebody must carry a product like it - essentially a spray on coating for pick-up truck beds.
IF you want a smooth black coverage from the paint, I would suggest Krylon, it goes on really nice, and looks glossy etc.
BTW, he used the TEACs to drive a pair of 4 ohm Totems and no problems at all.
